WTB red safety clip, rear seat 850 wagon Topic is solved
Has thanked: 293 times
Been thanked: 766 times
Post by erikv11 »
I need one of these, anyone have a junkyard run coming up? I would even take two if you can get them, why not!
This is a retaining clip for the fold-down hinge on an 850 wagon rear seat bottom. V70 may or may not be the same, I can't check as that wagon is living in another state this summer. Here's what they look like:
Clip working, in place with seat base folded forward.
broken clip
broken clip
The sedans do NOT have this part, it must come from a wagon.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1507 times
Been thanked: 3827 times
Eric...I'll check my 99 parts and advise.
Has thanked: 1855 times
Been thanked: 1717 times
V70 are the same. I'm going on vacation in a couple of days so I will check in with you on my return if you got one, if not I may have a spare seat I can remove a couple from.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
got a pair, they will be in the mail this week. Do you just need one set, or the other. Got my *** handed to me today, I will continue mortal combat with that beast tomorrow. Got the rear bumper, cluster and dashpad, and the calipers with 302 brackets, but I haven't quite liberated the struts or the 18T yet. The angle gear is right in the way of getting the oil drain line loose, then pull the CHRA, then get the buried manifold flange nut. Robert's video makes it look so easy!! :D
Current Volvos:
Post by erikv11 »
scot850 wrote: V70 are the same. I'm going on vacation in a couple of days so I will check in with you on my return if you got one, if not I may have a spare seat I can remove a couple from.
Key bit of info - thanks Neil.
FLXC90 wrote: got a pair, they will be in the mail this week. Do you just need one set, or the other. ...
Great news, thanks so much for finding these! I will send you a PM.
'06 S60 R, 197k
Post by erikv11 »
FLXC90 wrote: 09 Jun 2017, 23:28 got a pair, they will be in the mail this week.
Received - thank you, thank you!
'06 S60 R, 197k
