1995 940turbo
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bldrga
1995 940turbo
Post by bldrga »
I have never owned a Volvo. Considering 1995 940tubo with 90,000 miles as a third car for my children to drive. Appears in good shape. Well cared for car. Any words of advice from anyone who has experience with this model?
Volvord
Year and Model:
Post by Volvord »
Fantastic cars, The 900 series is an updated version of the 700 series which was first introduced in 1985. There are no problems that I am aware of with that model, they have all been worked out. The only real percaution is with the turbo, when ruinning around the city there is nothing special you need to do, but after a run on the highway let the engine idle for 10-15 monutes to let the turbo cool down before turning the engine off. If you turn the engine off right after a highway run the heat in the turbo will immediatly burn the oil in the bearing, called coking. The next time the engine is started the turbo will not have any lubrication which will cause premature failure, if looked after the turbo will last 500,000 mile, but I have also seen them coke up in less than 75,000 miles.
The milage on the car you are looking at is very low and sounds like it could be a great deal.
Good luck
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
dmonts
Year and Model:
Post by dmonts »
I am not a wrench but a very satisfied owner of a 1994 940 Turbo. I currently have 186,000 miles on car. I purchased it at 75,000 miles.
I have owned it 5 years and have had an incrediblely trouble free experience with the car. Very few repairs. Nothing major. No engine, transmission, or turbo problems. Mainly just regular maintenance done by a father - son Volvo shop close to me.
Best car, by far, I have ever owned.
DMONTS
DMONTS
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Damn, quit it... I want one. A wagon.
Also -> Amazon link
Farrington
Post by Farrington »
Volvord 784VC wrote:let the turbo cool down before turning the engine off. If you turn the engine off right after a highway run the heat in the turbo will immediatly burn the oil in the bearing, called coking. The next time the engine is started the turbo will not have any lubrication which will cause premature failure
Turbo Idle and Shutdown
Farrington
meant '95 not 86
matthew1
Site Admin
Post by matthew1 »
Farrington -- thanks for that very straightforward explaination. Do you know which year or model Volvo stopped using gen 1 turbos and started using gen 2?
Also -> Amazon link
Volvord
Year and Model:
Post by Volvord »
[quote="FarringtonTurbo Idle and Shutdown
1998 C70
