Steering rack fluid lines leaking
correllkp
Year and Model: 1995 850, 1996 960
Been thanked: 3 times
Post by correllkp »
Have an 850 Volvo with leaking fluid lines (see pics). Does anyone know where I can source these lines?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
The pressure and return lines are each available from FCP etc. They start around $100 apiece.
You can check junkyards for a better one.
Worst case, if your housing is rusted as well and just lines won't fix it, I have a spare PM me.
Current Volvos:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Check out FCP Euro and eEuroparts.com. Just a quick check on FCP shows a few hoses available.
Volvo Parts Lisle is also good for genuine parts: http://volvopartslisle.com/assembly/245 ... eering-Box
http://volvopartslisle.com/assembly/29573704/Pump
correllkp
Post by correllkp »
Thanks for the notes. The lines that are leaking are not the pressure and return line from the ps pump. The lines that are leaking are the fluid lines from the steering column part of the rack to the rack...sometimes called oil lines. If you look at a picture of a steering rack you can see these lines. IPD, FCP, the usual places do not sell these lines separately. But, FCP was able to find the part numbers and then I was able to source the lines. Should be here in a few days.
bmdubya1198
That's what I thought, it was hard to tell from the picture, which is why I posted both links for the diagrams.
FCP can usually find those kinds of parts for you. Glad you found them.
