Ive always
Flushed the car under idle with water running from the lower hose and also the reservoir, under close supervision always.
Stop car, let water drain out.
Reconnect, tighten hose clamps.
Add coolant to make up 50-50 based on advertised cooling capacity.
Idle and top up with water to FULL when warm.
A hot run at speed might mean another 100-200 mL coolant needed, but not more than that.
Weird Coolant Change Event...
- Has thanked: 1500 times
- Been thanked: 3812 times
Re: Weird Coolant Change Event...
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Draining it onto the ground is the worst way to get rid of coolant. Plenty of facilities accept used coolant. Drain it into a container and dispose of it properly. Don't be a jack ass.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
With the engine cold, fill the system to the top of the bottle. I often pump the top radiator hose while filling the system. The system is usually about 32 oz low after this process. When full, I put the cap on and start and drive the car for about 5 minutes. Then I let the car cool off for about 2 hours and remove the cap, fill it to the full mark. That usually does it for me. I'll check it the next day then a few days later.
You should NEVER try to fill the reservior with the engine hot.
- June
- Has thanked: 523 times
- Been thanked: 261 times
My husband used a large plastic tub under the drain in the radiator. Once the system was drained he would remove the upper radiator hose from the radiator leaving the drain open and attached the garden hose to the upper hose with a screw type hose clamp clamping the upper hose to the threaded end of the garden hose. He would then turn the water on and catch the rest of the coolant being pushed from the water running backwards. Then he would pull the tub out and run the hose full open and back flush the system. Then he would reattach the hose and shut the drain and fill the system back up with appropriate coolant mix. Junepolskamafia mjl wrote: ↑26 Jun 2017, 23:40Draining it onto the ground is the worst way to get rid of coolant. Plenty of facilities accept used coolant. Drain it into a container and dispose of it properly. Don't be a jack ass.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
You can dump small (one car) amounts of coolant into sanitary (Not storm) sewers for treatment by municipal facilities in most states, including NY - state of heavy regulation. If you do spill, rinse heavily to protect pets/animals.
I catch the main drain of coolant, and then the next bucket of coolant/water mix - at which point coolant conc is near zero
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 12 times
With a cold engine, I did fill almost to the top, expecting the 'sudden tank drop' as previously experienced. Pumping the hose with the t-stat CLOSED might help suck air through the t-stat bleeder. I didn't experience the 'tank drop' this time however during idle.rspi wrote: ↑29 Jun 2017, 08:26 With the engine cold, fill the system to the top of the bottle. I often pump the top radiator hose while filling the system. The system is usually about 32 oz low after this process. When full, I put the cap on and start and drive the car for about 5 minutes. Then I let the car cool off for about 2 hours and remove the cap, fill it to the full mark. That usually does it for me. I'll check it the next day then a few days later.
I have topped up to MAX twice now over the past few days and the coolant level has stabilized.
Another thing I had prep'd for then completely forgotten: Citric Acid Flush. I bought a few pounds of this stuff (food-grade), then forgot I had it on-hand to flush with! Rats.....
M1 10W-30 HM
M1 10W-30 HM
- rspi
Contact rspi..
I never flush.
