Weird Coolant Change Event...
Has thanked: 1500 times
Been thanked: 3812 times
Re: Weird Coolant Change Event...
Ive always
Flushed the car under idle with water running from the lower hose and also the reservoir, under close supervision always.
Stop car, let water drain out.
Reconnect, tighten hose clamps.
Add coolant to make up 50-50 based on advertised cooling capacity.
Idle and top up with water to FULL when warm.
A hot run at speed might mean another 100-200 mL coolant needed, but not more than that.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
abscate wrote: 25 Jun 2017, 05:15 That would be the best way to drain out all old coolant if you can't dump on ground and rinse with hose to protect pets.
Draining it onto the ground is the worst way to get rid of coolant. Plenty of facilities accept used coolant. Drain it into a container and dispose of it properly. Don't be a jack ass.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
With the engine cold, fill the system to the top of the bottle. I often pump the top radiator hose while filling the system. The system is usually about 32 oz low after this process. When full, I put the cap on and start and drive the car for about 5 minutes. Then I let the car cool off for about 2 hours and remove the cap, fill it to the full mark. That usually does it for me. I'll check it the next day then a few days later.
You should NEVER try to fill the reservior with the engine hot.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
polskamafia mjl wrote: 26 Jun 2017, 23:40
My husband used a large plastic tub under the drain in the radiator. Once the system was drained he would remove the upper radiator hose from the radiator leaving the drain open and attached the garden hose to the upper hose with a screw type hose clamp clamping the upper hose to the threaded end of the garden hose. He would then turn the water on and catch the rest of the coolant being pushed from the water running backwards. Then he would pull the tub out and run the hose full open and back flush the system. Then he would reattach the hose and shut the drain and fill the system back up with appropriate coolant mix. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
You can dump small (one car) amounts of coolant into sanitary (Not storm) sewers for treatment by municipal facilities in most states, including NY - state of heavy regulation. If you do spill, rinse heavily to protect pets/animals.
I catch the main drain of coolant, and then the next bucket of coolant/water mix - at which point coolant conc is near zero
Winnebago
Year and Model: 98 V70 T5M-R
Post by Winnebago »
is it so hard to give us a radiator cap??!!! grrr!
'98 V70 T5M - lots of R parts - 201k+miles
'98 S70 GLT - bought new. sold at 185k miles
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
rspi wrote: 29 Jun 2017, 08:26 With the engine cold, fill the system to the top of the bottle. I often pump the top radiator hose while filling the system. The system is usually about 32 oz low after this process. When full, I put the cap on and start and drive the car for about 5 minutes. Then I let the car cool off for about 2 hours and remove the cap, fill it to the full mark. That usually does it for me. I'll check it the next day then a few days later.
With a cold engine, I did fill almost to the top, expecting the 'sudden tank drop' as previously experienced. Pumping the hose with the t-stat CLOSED might help suck air through the t-stat bleeder. I didn't experience the 'tank drop' this time however during idle.
I have topped up to MAX twice now over the past few days and the coolant level has stabilized.
Another thing I had prep'd for then completely forgotten: Citric Acid Flush. I bought a few pounds of this stuff (food-grade), then forgot I had it on-hand to flush with! Rats.....
M1 10W-30 HM
rspi
Post by rspi »
I never flush.
