Do you have a VIDA?sugarman wrote: ↑14 Jul 2017, 19:52 Hi,
I am having the exact same problem. I have the Bosch ETM on my 04 S80 but I took it off and cleaned it along with the connector- It didn't help.
Did taking the ECM out and cleaning it help? If so I'll buy the tool and remove both modules and spray electrical contact cleaner to see if it helps me. I just dont know what it could be.
There are several things that could potentially cause these throttle bodies to act up.
We need to see which specific diagnostic codes your ECU has stored.
Chances are the throttle body has failed. In some cases the issue is the electrical connection/pigtail.
Volvo DOES sell the replacement pigtail Volvo PN 31409380
Don't let some lazy dealer parts counter guy try to tell you they don't.
If you end up replacing the throttle body I highly recommend the Xemodex unit with an updated contactless internal TPS:
http://xemodex.com/us/product/electroni ... for-volvo/
I don't think Xemodex was selling this contactless TPS version yet when I replaced mine. I made sort of a ruckus about the whole thing on here back then. I thought the Volvo/Bosch replacement throttle bodies (with a newer PN) had adopted a back-compatible contactless sensor which other OEs who use these style TBs from Bosch have switched to. When I got my new throttle body I took a look under the cover and found a mechanical sweep sensor
