IPD sale Volvo Parts Volvo Parts - free shipping up to $25 Volvo Parts
Recent work axle/trans Topic is solved
aahmes57
Year and Model: V70 1999
United States of America
Post by aahmes57 » Sun Jun 25, 2017 8:17 am
I have a 1999 v70 base 2.4 non-turbo. I just replaced an axle, control arms, sway bars, strut assy. And basically the same except the axle on the right as well.
I was test driving it yesterday, 70 mph on the highway road great. Today I was coming up a small incline 10 mph and I heard a pop and the transmission seemed to fall out of gear. put it in N
Could the axle shaft pop out of the transmission? Is the transmission shot? I can hear something that appears to be moving in every gear but it will grind trying to go into park.
I have to shut the car off to put it into park. 143 K Daily driver.
Not sure how to proceed. Just dumped hundreds.
Any help would be greatly appreciated.
Thanks John
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 13 times
Been thanked: 5 times
Peru
Re: Recent work axle/trans
Post by theWIFES_S70 » Sun Jun 25, 2017 12:27 pm
Hey John, axles have been known to pop out... Sometimes the circlip is faulty, or isn't there (if it's the driver's side axle). On the passenger side, because there's a carrier bearing holding it in, it's a little harder for it to pop out. I'd get the car on jackstands and tug and pull on everything. Control arms and ball joint should be super tight, same with sway bar links (I'm assuming you mean the links and not the bar right? I'd imagine a shop would charge at least $1K to install a sway bar!), and all the strut stuff, all of that should feel really tight.
Unfortunately, there are a lot (read, mostly!) crappy rebuilt axles for our 20-yr-old cars...
Did it pop out while turning?
1998 Volvo S70, N/A, 5-speed, 174K
1999 Nissan Altima, AT, 199K
polskamafia mjl
Poland
Post by polskamafia mjl » Mon Jun 26, 2017 8:25 pm
Get the front of the car safely up in the air and put it in drive and see what happens. You should be able to quickly tell if any of the axles popped out. It's been known to happen as mentioned above.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 97 times
Been thanked: 32 times
Post by matthew1 » Mon Jun 26, 2017 8:31 pm
Axle pop-out happened to me after axle replacement. Indications are that the transmission had given up (no drive/reverse) but what's happening is the output at the transmission is just spinning with nothing to turn against. All it takes is one axle out not two, because the sides are allowed to slip. The side that's popped out gets all the torque, and the good side gets none.
I had the same heart-in-throat moment that my trans was done.
Please buy from MVS sponsors. It keeps this site on the web.
Like this spam-free, organized forum? Thank a moderator.
Thanks for choosing MVS!
How to help MVS.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace
polskamafia mjl
Poland
Post by polskamafia mjl » Mon Jun 26, 2017 10:21 pm
Gotta love open diffs.
aahmes57
Post by aahmes57 » Tue Jun 27, 2017 8:12 am
Thanks so much for the answers to my post. From the sound of them it doesn't seem like I really screwed anything up to bad.
It happened (popped) when I was going straight not turning. I borrowed a tow dolly and got it home.
Hope to pull it back off tonight (rain) and get it back on the road. I hate driving a truck.
I know I lost alot of transmission fluid.
Thanks John
1995 850 sold
msmcrae
Year and Model: 1996 850
Post by msmcrae » Tue Jun 27, 2017 2:40 pm
I replaced an axle once, and didn't push it in far enough. Everything seemed fine, test drove up to 70 mph with no problem. When I parked it I saw I was losing transmission fluid, and figured out it was because the seal at the transmission wasn't tight around the axle (because the axle wasn't all the way in).
I was lucky, because the end of the axle had twisted a little during the test drive (because only a fraction of the splines were engaged) so the axle was ruined but at least it didn't snap off in the transmission or screw up the transmission.
If you lost fluid, it's probably because the end of the axle isn't fully seated, so I vote for 'popped out' as well.
aahmes57
Post by aahmes57 » Mon Jul 17, 2017 6:23 am
Hey folks, I can't seem to get an axle in there. The one that I thought popped out was not fully seated. Is it possible there may be a transmission that was replaced? I can only find one automatic trans for this vehicle. I just reordered another axle. The old one goes in and out no problem, I thought when it popped out it may have damaged the trans. Any experience and advice would be appreciated.
Having re-read the posts I may have damaged the first axle.
Thanks John
1995 850 sold
Has thanked: 22 times
Been thanked: 46 times
Post by erikv11 » Mon Jul 17, 2017 8:28 am
Is the circle still present on the one you originally pulled out? Maybe it, or a part of it, is stuck in the transmission?
I'd definitely try to align the old and the new axle side by side for checking length (and measure them carefully) and if you can get a calipers from HF for $10 measure the diameters at the splines.
'95 854 T5-R || m4.4 || 185k
'96 855 NA || 135k
'98 V70 GLT || T5 tune-injectors-turbo || 275k
'06 S60 R || 140k
gone: '96 NA 850 210k, '98 NA V70 182k, '98 NA S70 174k
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Spain
Post by shaker_chi » Mon Jul 17, 2017 3:53 pm
Where did you get the axle? If it is made in China, just throw it out, go to a boneyard and rebuild an O/E one. If you ordered a new one, did you make sure you got the right one. The manual and automatics are different part numbers. If you bought it from a non Volvo/European place, then they may have given you the wrong part. Lastly, once you pull out the axle shine a light in there and check the teeth on the transmission side. You should be OK. About 10 years ago I had a 1995 Maxima GLE and the mechanic put in the wrong axle. Same thing happened to me, but the teeth were still good. Good luck, hope all works out for you.
Eddie G
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: ecbsykes, FLXC90, gmh, Google Adsense [Bot], jvl, misha and 23 guests
