I know the high pitched electronic whistling sound of the throttle body.
Since A/C recharge by local independent, I get a high pitched whistling for between 4 and 8 seconds (approx.) whenever I first engage A/C or when I shut off A/C.
Any ideas as to what this might be attributable (and please don't say: "The A/C system")? It is definitely not the throttle body singing.
'99 S70 Base, FWD, Auto -- Whistling Sound-- AC?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
My Beetle has done this for three years. High frequency stuff usually means little damage
( there actually is scientific basis for that statement)
A little resonance in the compressor as it pumps up the high pressure side, perhaps?
With your awareness skills, just monitor for change and enjoy your AC
On edit...and if I had your comprehension skills I would have caught this
Happening on shut down too...almost certainly confirming a flow resonance somewhere , not to worrywhenever I first engage A/C or when I shut off A/C.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
My 95 has done that for years. Still working like a charm. Just to prove abscate's statement. Also, he is a mod, hence he's always right...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
JRL
- Year and Model: Several
- Been thanked: 16 times
Semi clogged Orafice tube?
Only when the AC is turned on? A clogged breather makes a non turbo whistle
- E Showell
Breather?
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 2199 times
Have you tried to use a piece of tube or a stethoscope to listen for the location on the noise? You will need the help of an able assistant to activate and deactivate the A/C.
