Axle CV
I really need some help here. I had bought a new wheel bearing for my front right wheel and so today I got to work. As you know, this job requires you to seperate the axle and the bearing itself to be able to replace it. When doing that, I noticed that the inner CV joint seemed kinda loose but I didn't think much about it, it should be able to move around, right? Anyhow I installed everything back and went for a test drive. After about 20 meters the right front wheel started making "clunking" noises. I noticed that the inner boot was busted so I rolled the car back into the garage. Removed the axle and the CV joint boots. While removing the inner boot, small balls fell out. After cleaing everything from grease, I could take a look at the joint. It looks undamaged, but for some reason I can't manage to put it back together, is it even possible? This is how it looks now after some tries I have concluded that this is the only way it fits:
In this way though, it won't move anyway but up and down a few millimeters. Sure I don't have any grease in it, but it should be able to move a little bit at least. So now I have a couple of questions:
*How do I repair this? Is it even possible?
*How the hell can the cv joint just split by itself?! Think if this happend during high speed!
Axle CV inner joint came loose by itself!
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 36 times
I don't know if there are any unique characteristics specific to the Volvo inner CV axle boot and joint, but Eric the Car Guy has a great breakdown of the inner joint and boot. As far as I'm aware, doesn't the clamp and the boot hold it (mostly) together?
Glad you're safe. This is some scary stuff...
Retired:
2015 Volvo S60, T5, 85K
baxtex
- Year and Model: Volvo S70 99
Hmm interesting. I did pull my axel back and forth and so if it that loose on Volvo cars aswell, no wonder it fell out! Just wonderinhg how to put it back together. :StheWIFES_S70 wrote: ↑03 Aug 2017, 09:57 I don't know if there are any unique characteristics specific to the Volvo inner CV axle boot and joint, but Eric the Car Guy has a great breakdown of the inner joint and boot. As far as I'm aware, doesn't the clamp and the boot hold it (mostly) together?
baxtex
Googled some more and managed to solve it! For future reference:
While repacing front shocks, mine came out aswell.
Here are some good videos how to do it.
Main thing here is do balls one in a time and slowly move cage and shaft around to get next ball in. Last ball is very tricky as almost all balls and ring have to come out more than half way. Very impotrant - short side of shaft sits opposite to long side of hub and so on 6 times. You can do it long to long side, but then cv joint wont move around, but sit in one position. Ford Mondeo uses same system. Good Luck!
- Has thanked: 1503 times
- Been thanked: 3817 times
The CV joint only goes back together one way, the " other way" isn't right
If it locks up you when you try to tip it through full range of motion it isn't right. If it is right, the balls fall out if you tip it too much. It's not hard to inure it out looking at it, it's even easier if you put a dimple punch mark on the face of the inner and outer race to align on reassembly.
