Kallekula's $350 S40 Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Got a really sweet deal on a 2005 S40 recently. The engine had overheated and the head was warped.
I began with spilling a couple of gallons of water inside the car so I had to take the seats and all of the carpet out to dry :evil:
Next i replaced all interior lights with LED ones, looks really good at night. Also refurbished the headlights because the plastic had turned completely yellow.
Currently replacing piston rings while the head is at the machine shop. Here are some pictures:
BMW 540i 2002
S70 Base 2000
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Good find! How much do you expect it will cost you to rebuild the engine? How much are you doing yourself?
kallekula
Post by kallekula »
MadeInJapan wrote: 12 Aug 2017, 21:12 Good find! How much do you expect it will cost you to rebuild the engine? How much are you doing yourself?
I have calculated that all parts needed and machining the head will cost around $700. I'm doing all the work myself except the head.
BMW 540i 2002
S70 Base 2000
MadeInJapan
That's awesome!! Keep us posted on your progress.
kallekula
Post by kallekula »
Finally got some time to work on the S40 again :)
Cylinder 1 honed
Cleaning piston
Piston after cleaning
Oil pickup looking pretty clogged
Oil pickup cleaned
Lazy as I am I had the machine shop clean the oil pan
One down four more to go
BMW 540i 2002
S70 Base 2000
MadeInJapan
That's awesome, Kallekula!!
kallekula
Post by kallekula »
Should have gone to church today but worked on the S40 instead :roll:
BMW 540i 2002
S70 Base 2000
MadeInJapan
So very clean- great job!!
kallekula
Post by kallekula »
Bought the last parts for the S40 yesterday. Gonna try and put it all together this weekend.
MotoRad thermostat
Timing belt kit with Aisin waterpump
BMW 540i 2002
S70 Base 2000
MadeInJapan
Awesome job! Glad to see you're not cutting corners with this repair.
