looking at receipts Ive replaced sensors 4 times 6 mo apart. is this unusual and any ideas why?
thanks
Bob
199v70 intermotor coolant temp sensors dead in 6 mo?
- Has thanked: 292 times
- Been thanked: 765 times
Ideas:
(1) if they are cheap, aftermarket sensors, some won't even work when new.
(2) check the wiring and the connector, they aren't falling apart are they?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1505 times
- Been thanked: 3817 times
It's not record breaking, we just have never had anyone replace that many that I recall.
I'm on my original.
I guess it's record setting,,,,
I'm on my original.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Mine is original too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
I suspect you may have corrosion in the connector or a harness issue to run through that many. IIRC Intermotor in some cases literally takes Volvo parts and puts them in their own boxes - I know that was the case with my ignition switch. It doesn't sound like this is one of those parts however based upon the high failure rate...
What are they doing to test and verify they are bad?
- 1139 Views
Last post by richardgengle
- 10729 Views
Last post by packetfire
