199v70 intermotor coolant temp sensors dead in 6 mo?
bobdog
Year and Model: 1999 v70
Post by bobdog »
looking at receipts Ive replaced sensors 4 times 6 mo apart. is this unusual and any ideas why?
thanks
Bob
Has thanked: 292 times
Been thanked: 765 times
Ideas:
(1) if they are cheap, aftermarket sensors, some won't even work when new.
(2) check the wiring and the connector, they aren't falling apart are they?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
bobdog
Post by bobdog »
Hah, yes, I've had the odd DOA, but on the other hand, the warranty is never out. I just wanted to be sure-ish another issue wasnt the underlying cause. Thermostat is tested and opens fine.
Bob
Has thanked: 1506 times
Been thanked: 3819 times
It's not record breaking, we just have never had anyone replace that many that I recall.
I'm on my original.
I guess it's record setting,,,,
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Mine is original too. ;)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I suspect you may have corrosion in the connector or a harness issue to run through that many. IIRC Intermotor in some cases literally takes Volvo parts and puts them in their own boxes - I know that was the case with my ignition switch. It doesn't sound like this is one of those parts however based upon the high failure rate...
What are they doing to test and verify they are bad?
