Just did the timing belt, cam seals and CVVT hub (on intake cam) on a 2002 S60 non-turbo.
I checked the timing and belt tension about 50 miles after completing the job just to be sure and everything looked fine. Plus I used a cam locking tool while doing the work.
After driving approx. 400 miles with no problems the P0012 code was thrown.
How quickly is the p0012 code normally thrown if the timing is actually off by a couple teeth? In other words, would one expect this code to show up right away if the timing is off?
If the timing really is off, is there a way to tell by how much its off?
I'll be checking the timing marks and tension again tomorrow...
thanks,
How long for a P0012 (intake cam pos timing over retarded) code to appear on '02 s60?
- Year and Model: Lots
- Been thanked: 128 times
What sort of cam locking tool did you use, was it the front type?
nikolajs
- Year and Model: 98 V70 T5, 97 850 NA
It bolts into the backside of the cams and then the two halves are bolted together.
IPD sells it: https://www.ipdusa.com/products/9735/12 ... cking-tool
Did you follow the procedure from Vida?
- 13 Replies
- 5051 Views
Last post by SuperHerman
- 10 Replies
- 2466 Views
Last post by erikv11
- 4290 Views
Last post by Smirniy
- 9416 Views
- 399 Views
Last post by buschman
