Ignition source for boost gauge light 98 v70 t5 Topic is solved
turtle1615
- Year and Model: 1998 v70 t5
- Has thanked: 2 times
I'm installing a Bosch boost gauge and need to find a 12v ignition wire but don't have access to a wiring diagram any help? Can be for headlights or just plain key on voltage. Would I be able to tap into the CD player wiring? it's aftermarket.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
You really have a couple options here.
You could use the dimmer line that comes out of the back of the dimmer switch. You could use a line from the radio.
2023 Lexus RZ450e -66k
turtle1615
Do you know what color wire to use from the dimmer switch?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You can access the dimmer's output from accessory connector.
Read through this post and you should find all that you need:
viewtopic.php?f=1&t=80795&start=20
The magic color for dimmer illumination is PINK.
turtle1615
That is exactly what I needed thank you!
- 9 Replies
- 2874 Views
Last post by 98v70dad
- 2075 Views
Last post by mecheng
- 1062 Views
Last post by Sommerfeldt
- 2279 Views
Last post by BodenM
- 346 Views
Last post by 1ezliving4ume
