Would a 900 Cold Cranking Amps (CCA) be too much for the Alaskan temps?
I currently have a 730 CCA and think I need some more 'juice'.
Thanks
Battery - Highest Cold Cranking For Cold Region
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Has thanked: 1611 times
- Been thanked: 4072 times
You can't have 'too many' cold cranking amps. The car will draw what it needs - a larger capacity will give you more cranking time, not faster cranking or more current.
These cars should start just fine, even in AK, if they are in good tune and repair.
Oka
The "more cranking time" is what I was refereing to, especially with our remote starters
that tend to go through more electrical processes to start.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Oh, a 900 cold amp would spin that puppy like a squirrel. More than enough. Just make sure to use a 0W30 (preferred) or 0W40 oil with a good filter such as Mann (if you are just switching to synthetic, keep a weekly eye on the oil level and perhaps replace the filter after only 500miles again). I had mine turning quite easily at -15F with an old battery with some 680 amp cold. You'll surely get a bunch of -40, but a fresh battery and correct oil will take care of it.
By all means make sure the thermostat has been replaced. It fails open after 8 years, the engine will keep cold for long and the PCV doesn't like that - neither your feet will.
On your really cold snaps I imagine your car will be happier with a block heater or even a oil pan pad, -40F is just down right nasty.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The OE block heaters are completely useless for actually warming the engine up. A hose heater would be a better option. Especially the modern ones with a pump to circulate the coolant.
But apart from that a battery charger would be just as good an investment as a larger battery depending on you usage pattern.
- oragex
And I remember years ago, they got -40 straight for a couple of weeks without a day of relief. Alaskaabscate wrote: 06 Oct 2017, 15:11 On your really cold snaps I imagine your car will be happier with a block heater or even a oil pan pad, -40F is just down right nasty.
One other 'trick', especially for older batteries, if the weather goes crazy, nothing better than pulling the battery and keep it inside the house over night.
Oka
". . . in good tune and repair" could be relatively subjective; a 2001 car would have some unforeseen ailment.abscate wrote: 06 Oct 2017, 09:23 You can't have 'too many' cold cranking amps. The car will draw what it needs - a larger capacity will give you more cranking time, not faster cranking or more current.
I have two little ones which adds to the issue of a "good" responsive start. The battery is five years old and
I just want to change it. With the remote starter, that "more cranking time" is my goal.
Thanks for your info.
So if the car has to reliably start ....
New battery
New battery cables
Pull starter and have it rebuilt or at very least test current draw, compare to new spec
Learn how to bypass ignition switch on your model
Evaluate plugs and coils and carry spares
All these are much better than some more cranking amps
New battery
New battery cables
- 4377 Views
Last post by oragex
- 716 Views
Last post by cuhfs
- 14 Replies
- 5082 Views
- 4941 Views
Last post by NateTheGreat
- 3753 Views
Last post by FLXC90
