Brake booster
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
TheOEL
Year and Model: C30
Brake booster
Post by TheOEL »
I have been having a problem with the Vacuum switch that controls the vacuum pump. Eventually I bought a new hose from U.K and now have to fit it. As the booster is on the opposite side of the car with a right hand drive car the hose assembly and vacuum sensor are different, however, the fitting into the booster drum looks to have the same fitting as is on the actual vacuum switch for L.H.D. cars.
Has anyone had experience getting this hard plastic fitting out and/or back in?
Vacuum hose end
Vacuum hose end
P1040225 (Medium).JPG (82.76 KiB) Viewed 347 times
