ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by ZionXIX »
Rustyprelude wrote: 27 Nov 2017, 13:08 I finally pulled a bunch of stuff out of my dash behind my radio. Turns out I need to put the blue adapter back in, since its for the CD changer. Not pictured is a mini-coax cable that runs to the antenna in the rear window. Anybody know what this stuff is for?
Judging by the Motorola logo on the box, I would guess that this was some sort of hands free setup from way back in the day.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Drove it to Home Depot to pick up some containers, spackle, other stuff, about a mile away :-)
That's all i did (yesterday) because i have not had a chance to do the other things i have planned yet.
I try to take a monthly snapshot of the ECU monitors though using a camera so i have a record.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
Today, I replaced the broken rear-view mirror in the 2000 V70 — with one I bought off eBay for $19 shipped!
The process was easier than I had expected. After gently prying out the map light covers with a small screwdriver in the top-side slot, I removed the plastic lighting assembly with a T-10 Torx bit.
Two T-30 Torx screws hold the metal plate that secures the mirror assembly to the car's frame. They were easy to remove with the mirror part missing, though I had to bend the new one out of the way to get a socket + wrench in there.
I forgot to take a picture of the new mirror because I was headed to work, but it works much better than the previous, non-Volvo one that had been glued to the windshield before falling off. I had propped it on the dash, making for interesting reflections, though they weren't all that useful for gauging traffic.
Map lights off: Rear-view mirror removal, 2000 V70
Light assembly off: Rear-view mirror removal, 2000 V70
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
rodkenney
Year and Model: Volvo 1999 V70R
Post by rodkenney »
Just purchased my first 1999 V70R today for $1300.00 Today was a good day... :D
MrAl
Post by MrAl »
rodkenney wrote: 28 Nov 2017, 21:50 Just purchased my first 1999 V70R today for $1300.00 Today was a good day... :D
Cool. What shape is it in?
Has thanked: 1497 times
Been thanked: 3810 times
Welcome Rod!
Having bought the much coveted 1999 model, when you have time drift over to the " bastards " thread to cover the special needs of the 1999 2000 years
These models have a few things that are different from the rest of the Forum.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Waiting on pics :D
brunocerous
Congratulations! That's less than I paid for my 1998 V70 base with 146k miles in 2013.
What's first on the repair schedule? :)
brunocerous
A day after trying to get this oil filter housing off the 2000 V70 by hand, I gave up and took three trips to AutoZone and one to Advance Auto Parts to settle on a filter wrench. The plastic housing has a torque spec of 25nm but I swear it's more like 250nm.
After clawing up the exterior for a few minutes, I finally cracked in loose and it continued to be so tight that I kept using the plier-like tool almost to the end. (The oil filter was filthy!) Popped the new one in, and it was tough to get the housing back on. Is that normal? Should I replace the plastic housing for the oil filter?
I thought this was all supposed to be fun!
Oil filter housing, 2000 V70
bmdubya1198
The oil filter canister on the '99+ can be a pain to remove without the right tool. You need a special size oil filter wrench like this one: https://www.ebay.com/itm/VOLVO-Cap-Styl ... SwEK9UEwFj
Definitely worth buying it to have on hand! My cousin and I were so confused the first time we changed his oil because we could not find a way to get it off. Ended up having to leave the filter for next time. He has the wrench now and it comes off no problem every time.
