Hello everybody
I ordered a new mambatek actuator , because old one needs to be changed. Mambatek actuator comes with 5 different springs, and has already installed a 9psi one. My turbo is TD04HL-13G and engine is 2.0(207 hp,b5204t), and factory boost is about 0.7 bar so about 10psi. The preinstalled spring is a bit weak i think and i would like to know if i could put inside the actuator the 0.8bar/11psi spring. Is it safe without any ecu tune? Should i stick to the 9psi spring ? What are your thoughts guys ?
Thank you
Artur
Volvo 850R aftermarket actuator and spring preload
arturjarn1
- Year and Model: 1996 850R
- Has thanked: 1848 times
- Been thanked: 1710 times
Standard TCV is supposedly good for upto 12psi, but gets a little stressed over there and can flutter of 12psi.
Don't see 10 psi and 1psi being too different. You may feel a little difference on the road. 850R with a 2.0 liter engine. Who knew?
arturjarn1
Thanks for your response. Volvo made 850R's with 2.0 engines due to tax laws in italy
