Hello,
I can't find a solution anywhere.
So it's my '94 850.
When I turn to the 0 position the headlights switch, the dashboard lights go off, but the headlights remain on.
The other positions work as they should.
When I remove the key, everything is off.
I changed the switch with one from the junkyard, because I thought it was it the issue. Same problem.
I live in Sweden, the car comes from Norway, and in both countries we have to drive always with the lights on.
So I was thinking if there was a bypass directly on the headlamps wiring made by the previous owner. So he couldn't forget to switch the lights on.
I wouldn't care because it works, but the technician at the periodic car check up doesn't see it that way.
850 '94 headlight switch
watchmaker_of_death
- Year and Model: 850 '93
- Has thanked: 1502 times
- Been thanked: 3817 times
That's the correct function for Daytime Runnjng Lights
In the States we can turn these off by giving the little screw in the rear of the light switch a quarter turn counterclockwise , but I'm not sure you get this option in all countries where DRL are on all cars.
watchmaker_of_death
No we don't have this little screw in Europe.
In Europe, daytime lights, it's the high position of the switch. We have to be able to switch them off just by turn it to 0.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Yes we have!
All explained in user's manual.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
watchmaker_of_death
Oh, ok. I don't.
Thanks, I continue to investigate.
It could be your headlight switch was replaced , watchmaker. They do go bad sometimes.
Or, your car is just special.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
Maybe go back to the JY and find a switch that does have the "A" screw, misha pointed out?watchmaker_of_death wrote: ↑10 Dec 2017, 09:54 I changed the switch with one from the junkyard, because I thought it was it the issue. Same problem.
It's in my car too, and I live in Denmark.
Hope you get it sorted, a lot of the periodic check up technicians in Sweden aren't very forgiving as far as I remember from living there.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
watchmaker_of_death
Strange... Because I had a 96' 850 when I lived in France, and same, no 'A' screw... And it was an Italian or Swiss import.
But I suppose that, because this 850 is a Norwegian model, maybe set up with the norwegian regulations on DRL from the main headlights.
I'll check if I can cut somr wire in the switch or bend a pin.
