Hi all!
I recently replaced my PCV system, and in doing so I didn't tighten the bolt that holds the intake manifold to the bracket on the bottom to the correct torque. What is the size of the bolt so I can get a new one? Also, on a happier note, my terrible idling problems have gone away. I installed a new flame trap and vacuum tree, and removed and reinstalled the IAC valve, so my car now idles at around 850-900 RPM!
Thanks,
StubZz
12 MM bolt that holds the Intake Manifold to the Bracket
- Has thanked: 1850 times
- Been thanked: 1710 times
That is great news on the idling which is just where it should be now!
Not sure from your description which bolt you are talking about? The one for the dip-stick tube that fits from the underside or which one? Picture would help if you can.
- Has thanked: 1505 times
- Been thanked: 3818 times
Volvo parts lisle is my go to for exploded diagrams showing hardware and part numbers
I think every 12mm head bolt is a M8 thread
jimmy57
- Been thanked: 320 times
8mm 1.25 pitch and the dipstick one is 15 mm long, the brace is a little longer so likely it's 20 mm long. BUT, the description is sketchy so can you take a picture?
That jimmy57 was my point too. I think we are thinking of the same bolts but description is vague.
982793 for the dipstick
985186 for both intake manifold mount screws.
- 699 Views
Last post by jreed
- 118 Views
Last post by veezmachine
