Looking at the accessory belt routing, where it runs over the top of the idler pulley (not the tensioner pulley) it's on it's return trip to the crank pulley so spinning the idler counter clockwise. This would turn the bearing counter to the thread direction of the mounting bolt. The question then is that bolt standard threaded or left-turn for tightening.
Also, does the dust cap on that pulley just pop off?
850 question re bolt that holds acc belt idler pulley
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Based on a post from '08 (below), it looks like 18 ft-lbs.
https://www.matthewsvolvosite.com/forums ... hp?t=17913
VADIS lists the following:
Tensioner Pulley: 30Nm (22 ft lbs)
Idler Pulley: 24Nm (17.75 ft lbs) (if re-using, make sure and grease the bushing in this pulley).
Auxiliary Belt Tensioner 20Nm (14.75 ft lbs) for both screws...also the same value if you remove the center screw of the tensioner to regrease the internals.
- 24 Replies
- 4734 Views
Last post by sleddriver
- 761 Views
- 3926 Views
- 227 Views
Last post by veezmachine
- 1142 Views
