850 t5 conversion
misha
Has thanked: 152 times
Been thanked: 402 times
Re: 850 t5 conversion
Post by misha »
It would start for 2 seconds and die when immobiliser,chipped key or antenna ring have faults.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Seany27
Year and Model: 1995 volvo 850
Has thanked: 3 times
Post by Seany27 »
But I wouldn't be getting a spark
Has thanked: 1850 times
Been thanked: 1712 times
Is the car an automatic or manual trans. Have you changed the type of trans say from an auto to a manual?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Seany27 wrote: 19 Dec 2017, 15:02 But I wouldn't be getting a spark
How long can you keep the car running if you continue to give it fuel?
85 GLH, 367 whp
00 Insight, 72 mpg
Seany27
Post by Seany27 »
The cars a manual, but the harness is from an auto, I've already wired up the pnp switch and reverse lights, soldered and sealed.
Seany27
Post by Seany27 »
I wasn't able to put more fuel in, everytime I put fuel in was by taking the spark plugs out or the injectors
Seany27
Post by Seany27 »
Starter fluid banged in today, still cuts out after a few seconds, good spark, going to check if the ecu has an immobiliser, anyone know where to start with that?
Seany27
Post by Seany27 »
New wiring loom got today from a 95 t5. The other wiring loom is thought to be 96+, wish this rain would piss off so I can get on with it
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
It will, to be replaced with s**w... Stick with the rain, it is the better of the two evils!
Seany27
Post by Seany27 »
Same problem with the 95 harness, can't get a break. Going to see a guy at volvo on Monday, see if I can get any answers. Oh and it's definitely not immobiliser.
