Greetings!
I've noticed that my "00 V70 starts almost immediately upon turning the key, while the '98 V70 exhibits a brief *thuk-thuk* before it actually starts. The delay is maybe a second long.
The older vehicle hasn't had problems starting, though at 185k miles, I'd expect age takes its toll. The newer vehicle is at 182k miles, and I've only owned it a few weeks.
Could it be a sign of a worn or failing starter, or other component? Are there preventative maintenance I should be doing?
Thanks in advance!
How long should it take to start? Topic is solved
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 2210 times
I'd check all the high current cables and ground cables, as well as the battery condition. Finally the starter is 20 years old possibly so they can get weak with age.
brunocerous
Thanks, Neil. Much appreciated.
It's not something I would've noticed without the newer V70 as reference. The battery is two years old, but I have no idea if the starter is original. I'll check that, too. Do they usually fail completely, all at once, or will it be a gradual process?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Don't worry.
98 v70 have cap & rotor while '00 v70 have separate coils over each cylinder.
Totally different cars in the way of engine management and you can't really compare them.
If your starter fails you wouldn't be able to crank the engine.
So....if it starts and runs ok...leave it alone.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Typically a gradual process until they hit the tipping point. But try checking the cables and grounds which will reduce the efficiency of the starter.
- Has thanked: 1611 times
- Been thanked: 4075 times
I've got a like new Volvo starter just waiting for your call. I think it's priced special for NJ
I don't think your starting is problematic. Just pay attention for changes.
brunocerous
Thanks, everyone! I knew about the distributor vs. coils but hadn't considered that in the differences with starting the two vehicles.
Good to know, Abscate! Thanks!
Even the coil v's are different. I have an AWD V70R and a FWD V70 NA/base and the 'R' I have to turn the key to II and let the pressure in the fuel system build slightly or I find it churns a little before starting. If I do this it starts almost instantly, even with new fuel pumps in the AWD saddle fuel tank.
The FWD starts almost instantly when the key is turned.
Having said that we had a 93 850 GLT (non-turbo) and it started instantly. So perhaps it is to do with fuel pressure build also?
Ignition and fuel pressure management different. I bet that contributes.
JimBee
- Has thanked: 33 times
My 93 850 has always started instantly, even in the coldest weather.
My 2 96 850's (2.4 and 2.3) take a few turns of the engine before cylinders fire, even if i leave the key on pos II for a few seconds, makes no difference. All are tuned and run well.
My theory is engineers built in a slight delay so some oil would pump into the bearings before startup.
- 474 Views
Last post by MoVolvos
- 19 Replies
- 3736 Views
Last post by obayha
- 15 Replies
- 3069 Views
Last post by erikv11
- 821 Views
- 5722 Views
Last post by Volvoblackdog
