2010 S80 Steering Wheel Air Bag Removal
I want to replace the trim ring (peeling coating on the plastic is a bit sharp) on the steering wheel and first need to remove the air bag. I have tried several torx sizes (25, 27, and 30) inserted in the two holes in the real of the wheel but none seem to fit. Does anyone know if this the correct method? If yes, the correct torx size? Any further instructions would be appreciated. In advance many thanks.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If it's the same system as in the video, it's not a torx screw, it just like a tab, a regular flat screw driver inserted then pushed somehow upwards to unclip the tab
- SuperHerman
- Been thanked: 207 times
It is like Oragex says. Just turn the wheel so you can get the screw driver or other tool in there - it cannot be too long - but neither too short.
- 1128 Views
- 2448 Views
Last post by Ozark Lee
- 23 Replies
- 1059 Views
Last post by 8pack
- 16 Replies
- 1740 Views
Last post by TimothyJ
- 620 Views
Last post by treestone27
