2005 V70NAM56 No start condition, prelim diagnosis 30742823 Topic is solved
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Re: 2005 V70NAM56 No start condition, prelim diagnosis 30742823
Post by matthew1 »
abscate wrote: 17 Jan 2018, 08:15 PS - off topic - what kind of car warns you that the FPCU is going one week before two long trips by futzing out 1/2 mile from home, then getting you home, then promptly quitting again making diagnosis in the driveway easy?
A car who loves you.
BTW, "2005 V70NAM56" is the highest information density ever in a title here at MVS. ~13 characters and we have a wealth of information to start with. If MVS had an Information Density Trophy™, you'd get it.
Also -> Amazon link
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
This morning's festivities attached...
Car has about a 5 PSI variation from the pump at idle until it warms up.
Turned fuel pump on from VIDA and on the 3rd or so attempt, she fired right up.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
There is a board soldered relay for fuel pump in CEM. It is the source of power on A16 at CEM. On your car it feeds PEM. You can check it with voltage drop between pos post at engine fusebox to CEM A16. Not a high failure rate that I am aware of but 2005 is the first year of P2 CEM II so it is the oldest and the age related failure, if any, may now be showing up. Monitoring A16 should be done when pump runs. Also a good idea to run a wire that you back probe into A16 and check voltage there at several starts and while running to see if there is no voltage or low voltage there to determine if that is the problem or you focus on no command to PEM, PEM, or fuel pump.
Has thanked: 1505 times
Been thanked: 3818 times
Thanks Jimmy.
That explains a lot. I kept seeing references to the fuel pump relay but no such animal appears in wiring diagram, since it’s internal to the CEM.
Without VIDA I was able to get to fuel pressure sensor, pump ekdctronics module, or fuel pump as cause
VIDA now tells me to check fuel pressure sensor, PEM, or fuel pump.
Gotta love it!
I think next step for me will be (warmer weather next week) removing the PEM and inspecting for corrosion and also monitoring the 12V Feed to it from the CEM.
This is a steel fuel tank V70 , by the way, which VIDA says is not eligible for the PEM relocation into the spare tire well. Hmm. I wonder why not?
Nailed it
Checked voltage from A16 CEM to PEM and it was perfect at B+
Pulled and opened PEM and it was full of crud
Cleaned with electronics cleaner and car started
New one on order
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Too much leakage current. Did you figure out where the crud was getting in and seal it?
I received the trophy this morning Matt, and I understand to keep the engraving costs down you acronymmed it to
IDIOT
:lol: :lol: :lol:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
All used PEM fit all cars from S60 XC90 S40 etc from early 2000 up to about 2012 for the S40. Late S40 have them inside the car under rear left seat unde the carpet corner away from humidity. On those located outside, corrosion builds on the cooling plate and
damages the circuit board inside. By the way these are pretty funny to split open as the cooling plate is attached to the circuit board with several welds, I think a heating gun is needed.
