Best way to get trans fluid out of transmission?
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Post by T64me »
My 1996 Volvo 850 was in an accident and the radiator was damaged which allowed coolant into the transmission cooler. I've replaced the radiator but now I am wondering how to get as much contaminated trans fluid out of the transmission as possible before I refill it. I know I can pull the drain plug, but there will still be fluid in the transmission itself. If I leave the lines that go to the transmission disconnected from the new radiator/cooler and start the car, will it pump out the remaining contaminated fluid? If so, do I need to put the car in drive to do this? Obviously, I am concerned about damaging the transmission so any input on how to avoid doing so would be appreciated.
Thanks in advance for any constructive input.
Erik
Has thanked: 292 times
Been thanked: 765 times
With the car in park, disconnect the top line from the radiator, and hook a clear tubing onto it leading to a container. Start the car with trans in park, and it will start pumping fluid. Your best bet is to do a continuous exchange until you get bright pink fluid pumping out of the trans. That will take about 14 quarts. You can feel very comfortable using cheap DexIII from Walmart for this procedure, thats what I give all of my 850/x70 transmissions.
This procedure is written in great detail in many places and videos, here is one of the original posts about how to do it: viewtopic.php?t=8767
Good luck!
Erik
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1505 times
Been thanked: 3818 times
Erik - is this in famous Gibbons method, invented by..
Has thanked: 1850 times
Been thanked: 1710 times
Looks like a mechanic that worked on my car....maybe he was so bad as they paid him peanuts...!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
He was a real "Grease Monkey", huh?
Current Volvos:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
This topic turned funny, yet strangely true.
