Trying to buy this coolant hose, can’t find it
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
I need to replace the coolant hoses on the wagon before I address any other less urgent issues. Most of them I’ve inspected are in really bad shape.
I can’t find the small hose in the back of the engine compartment on the passenger side for sale anywhere and I’m not seeing it in part diagrams.
Anybody have a part number or what size generic coolant hose I should get if it’s not available? I’m thinking one inch diameter or so but I haven’t measured it.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Thats goes over toward the turbo on that main hard line... Give me a few, I'll find it =)
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
wizechatmgr
I believe that's the one... Beat me to it... =)
wizechatmgr
Make your life easier - when you get it, install it with the part number facing out =)
Been thanked: 466 times
Post by cn90 »
- Yes, use only Volvo OEM hose for that. I used a fuel line hose (it was a weekend) which barely lasted one year, then developed pinhole leak, simply b/c it is above the exhaust. This is why the Volvo OEM hose is better, it has silicone on the inside.
- By this time, you will definitely need to replace the 2 Turbo coolant hoses if not already done so:
viewtopic.php?t=55306
jtp
Post by jtp »
Got it. Yes I’m doing everything, even the heater hoses. You can’t tell from the pic because the car is ice cold but even that one is swollen and weak looking when it’s been running, and it’s not even one of the worst looking ones.
I had read the turbo coolant hoses were such a pain i assumed they were both down closer to the turbo where it’s hard to reach, at least that one will be less of a pain then the other I guess. Thanks!
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
When you do the heater hoses going into the firewall, replace the junction at the same time. It will get damaged when you disconnect those hoses.
Post by cn90 »
jtp wrote:...Got it. Yes I’m doing everything, even the heater hoses. ...
For HEATER HOSES, no need to buy Volvo OEM hoses (expensive @ $55/each, BTW stay away from URO!), instead I use generic Gates hoses as below.
I did this 3 years ago, so far so good, zero issues.
You basically re-use the fittings and get ird of the firewall coupling, eliminating the stupid firewall coupler design.
It is a very very but effective mod.
- At this age, consider replacing the heater core too (search forum for the Estonia heater core, about $50 on ebay).
DIY: 1998 Volvo S70 GLT Heater Core, Heater Hoses Rebuild!
viewtopic.php?t=69238
