Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
I should've known making a witty remark would come back to slap my rear end.
Today, I was on the way to visit my dad in hospital and had my mom with me in the car. I had to change into 4th gear and the clutch pedal gave way halfway through and it just ended up sitting stuck to the floor. I worked my foot in underneath the pedal and got it back up, and found it impossible to push down. Turned around and drove back home without the clutch while swearing and trying to keep from coming to a complete stop at any time.
There's a lock ring or circlip that holds the clutch slave cylinder in place and after 22 years of being married to the slave cylinder it apparently had had enough of that. I found the circlip happily hugging the piston dust cover and it took a fair bit of coercion and twisting its arms to get it back to where it belongs. The slave cylinder sits right where it's supposed to now, hopefully it'll stay like that for another five or six years which is how long I plan to keep the car running.
Unfortunately, before I got the slave cylinder back in place, I just had to test if either of the cylinders had seized. I stepped on the clutch pedal until it suddenly sank to the floor, thereby shooting the piston out of the slave cylinder, breaking off part of the plastic neck for the dust cover in the process. I removed it from the car and carefully pushed the piston back in place wtih a C clamp, tested to see if the seal was still intact and heaved a sigh of relief when I found it able to hold a vacuum.
Now, I'm about halfway through airing out the clutch, had to stop due to lack of daylight and because of wind picking up. Tomorrow, I'll either complete the job or run out of brake fluid.
Found this tool to be the only way of me getting the air out of the clutch cylinders and piping, used it to swap out the brake fluid when I bought the car two years ago:
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Has thanked: 1611 times
Been thanked: 4075 times
Teddy - at least when you get a clutch problem, you don't have to take your engine out. I love the internal release bearing/slave cylinder design, but when I bled my 1999, i was on eggs the whole process.
The 2005 was easier as I already had the trans out.
Teddy1975
Post by Teddy1975 »
I was lucky it happened when it did, only 20 miles from home. Friday I went through an hour of stop-and-go rush hour traffic on the freeway. I would've chickened out and called for a tow if it had happened then.
I'm a big fan of the master/slave cylinder and spring-assisted clutch pedal system when it works. Not so much when it spews brake fluid all over the engine room. And it's a royal pain in the rear to bleed it properly, especially since I didn't think it necessary to remove the radiator fan shroud to get more room. Pedal is still a bit spongy now, but at least it no longer just drops to the floor when someone looks at it, so I'm getting there.
Garaba
Year and Model: 1998 V70 XC
Post by Garaba »
Started hunting down a CEL related to the fuel system. Ordered a new gas cap, going through replacing all the hoses I can. Because its cheep and easy.
Just when I thought I got her to Stage 0...
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Garaba wrote: 05 Feb 2018, 13:40 Started hunting down a CEL related to the fuel system. Ordered a new gas cap, going through replacing all the hoses I can. Because its cheep and easy.
Good luck! I've got to do the same before April when my inspection is due. I've had P0455 hanging around for a long time.
Used my 99 as a mobile garage to store tools fir my Beetle air bag sensor replacement
Step one. Remove entire front of car.
:shock:
brunocerous
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
abscate wrote: 03 Feb 2018, 08:49 Getting my engine and turbo tuned up for an upcoming race with bmwNC and June
Heres my time trial - see you soon in the rear view, kids..
:-D
Whoa, my heart skipped a beat for a moment! The fastest I ever went in my 97 VW Golf was 120 mph on a desolate Colorado highway.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
brunocerous wrote: 07 Feb 2018, 11:37
:-D
Fastest I've been was around 125 on a lightly populated Florida highway keeping up with my cousin we were visiting. I wasn't driving though... I'm not that stupid! Florida cops are not very nice... I can't believe none were around!
147 mph in this state will get ypu locked up
As wcm cleverly noticed, I turned Waze on just as I was touching down in an EMB 145 at KALB runway 1
Well, in the world of pain in the derriere , I have pushed P80 alternator Tetris far down the list. This was caused by in order to reach this
Photo pending
I had to do this
Photo pending
