Head gasket job. Won't start
Been thanked: 4071 times
Go to Full editor, then add attachments, load em and post em
Then write a memo to Matt that drag and drop doesn't work.
Has thanked: 311 times
Been thanked: 817 times
Kazbear wrote: 09 Feb 2018, 12:41 ... Now I have a major coolant leak, but I will track that down. Seems like it's from the water pump. ...
Check on the side of the head near the passenger side firewall, where the water pipe connects. Pesky and inaccessible, the paper gasket often gets folded or dislodged causing a leak there.
Kazbear
Year and Model: 2000 v70
Post by Kazbear »
erikv11 wrote: 09 Feb 2018, 13:33
Ugh! Yeah, that was a pain
Kazbear
Post by Kazbear »
bent exhaust valves
Valves Image
Lifter
Piston
Cleaned and Lapped
Kazbear
Post by Kazbear »
Well, this is fun.
It would appear that I have now stripped one of the threads in the head at the pipe.
Do you think I will have any luck with some kind of thread repair kit? Helicoil?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I like these:
Kazbear
Post by Kazbear »
As you know, the location of those bolts is not easily accessed. I dread pulling this head off again.
If anyone has some kind of magic self tapping bolt suggestion, I would be elated.
loosenut
Year and Model: 2006 V70R
Been thanked: 7 times
Post by loosenut »
I have a trick that will work..........never fails..
loosenut
Post by loosenut »
ok so in case anyone needs this trick...
take the bolt and hold it with a pair of vise grips on the head.
take a sledge hammer and smash the threads flatten them a bit on both sides so then you have an "oval" type bolt.
then this new bolt will cut new threads use the proper torque and walaa....
Lol at the drama of it all ... but nice tip!
