Today, my 1999 V70 abruptly lost power. At idle, with the transmission in P or N, the engine lurches back and forth between about 700 rpm and 1200 rpm. In P or N, I can rev the engine by pressing the accelerator.
In gear, there's no throttle response whatsoever. The idle continues to oscillate, and the car rolls a bit in response, but stepping on the gas makes no difference at all.
For what it's worth, the weather has been very rainy for the last several days.
Thanks to any and all for your help.
V70 Erratic idle, no power
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Check your fuses.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Are you using a KAE fuel pump relay?
Knows enough to be dangerous
- Been thanked: 4068 times
If you have over 150k miles on it, the throttle body could be near end of life.
Your description sounds a lot like limp mode, which is what the car does when that part dies
Any lights on on dash?
Have pending codes read at an autozome or buy a cheapish reader that's will read pending codes ($35 or so)
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Make sure the battery isn't low... When I had an alternator go I experienced the same symptoms when I went well below 12.5V. Once the battery was charged back up I had no further issues.
The ETM can be tested with VIDA. It gives a pretty little graph of both of the varistors sweep and the deviation from expected.
One other trick - put the car on a charger and place the key in "on" for a half hour. Come back out, turn it off, then start the car. I know I pissed my car off rather badly by not exiting the ETM test correctly. When this happens it will hit limp home mode for a time.
- 269 Views
Last post by Eliotlm
- 3444 Views
Last post by precopster
- 1432 Views
Last post by metalriff
- 1015 Views
Last post by saulgar1
- 1679 Views
Last post by mattmatt
