External tranny cooler
Stellablue
Year and Model: 2004
Post by Stellablue »
Hello,
I am New here. This site has ton of info thanks to all! I have 2004 xc70. Summer is coming, I get stuck in hot freeways, and was wondering if anyone has installed an external tranny cooler. If so is it worth it and any recommendations.
Thanks
SB
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Welcome to the forum! Don't hesitate to ask for other questions as well, it will surely help maintain the car and lower the repair costs.
I think there have been already external filters added, and perhaps also coolers, the owners will surely post their experience. Generally speaking, the transmission cooling system is quite robust on these cars, assuming the radiator fan is working properly (it can go bad sometimes).
What is important would be to replace the fluid with the correct type. Toyota type IV from Toyota dealers or Mobil 3309 would be the closes oils to the one sold by the main dealer. Still, if money is not a problem, I would definitely use the fluid from the main dealer, despite the need of about 15 liters to properly replace the old fluid. Volvo never recommended servicing the fluid for most cars, which was a mistake. However they did recommend replacing the fluid in specific conditions, for the cars that are towing or being driven in hot climates on hilly areas. In such conditions the fluid heats up past the operating 80C temperature and starts loosing its properties. Most of the times the computer will throw a 'transmission servicing' message when or if the fluid has degraded past certain point from overheating. It will probably be easier to first replace the fluid, then see if an external cooler still may be of an added benefit. One thing to remember is the fluid replacement must not be done by a regular garage using a transmission 'flushing' machine. Instead, we replace it using a procedure described in several Youtube videos.
Has thanked: 1609 times
Been thanked: 4065 times
Stellablue wrote: 23 Feb 2018, 16:11 Hello,
I am New here. This site has ton of info thanks to all! I have 2004 XC70. Summer is coming, I get stuck in hot freeways, and was wondering if anyone has installed an external tranny cooler. If so is it worth it and any recommendations.
Thanks
SB
Welcome Stella...if you are in Skinny-apolis, Volvo doesn't consider that hot weather. Just change that fluid and change your engine coolant every 3-4 years and the stock system will be fine.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The stock system uses the coolant so you'd have to overheat that as well. A fluid change every now and then is a good idea regardless.
Stellablue
Appreciate the input, thanks. The fluid is looking a little dark. I have some 3309 ATf order up. I am hoping to get it changed before a storm that could dump 6-9 inches of snow on us today. We will see.
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
How many miles on your '04?
Might be prudent to check the fluid in your bevel gear.
Also, fuel filters are commonly overlooked.
FYI: Should you install one......
One trannie cooler retrofitted to our vehicles was the long wide one salvaged from 240's.
It fit below the radiator neatly.
The fellow even included dimensions of metal bits he fabricated for installation. I can't remember which forum.
Stellablue
There is approx 172,000 on the car. I drained and filled the tranny today. Man that fluid was grosser than I thought. Anyways, I got it back to tranny cherry red. It ran fine before but there is a definitely feels better. Maybe the placebo effect who knows.
Georgeandkira
Super! Did you pump it out via a disconnected cooling line or do repeated D&F's?
Stellablue
My daughters and I did it through the disconnected cooling line. I figured they should learn how to work on cars too. The fluid was really dirty. I am thinking about driving the car for a few hundred miles or more and do another.
Georgeandkira
How many quarts did you use?
If it's real clean now I'd drive it till warm weather at least.
How much "cleaning" the new fluid will do is argued and discounted.
Do what you like but I'd give it to June or July.
Where is Mpls?
