S70 Turbo: Returning Airbox to Stock Questions?
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Re: S70 Turbo: Returning Airbox to Stock Questions?
Post by WhatAmIDoing »
abscate wrote: 24 Feb 2018, 15:49 I have a spare MAF for my car and can measure the Oring. I think the 99 air box is the same as the 98?
Maybe?
It appears that 1994 to 1998 used the same MAF. 1999+ models had a different MAF. The housings do look a bit different, but can't tell if the coupling is in fact a different size. Worth a shot, thanks.
Only hit I've got for a part number is 1389108 which is an O-ring that installs on the MAF, but from the diagrams, it is very hard to tell whether it is the part I'm looking for. Volvo dealer 1.5 hours away says they can have it Wednesday for $11, but I'm not convinced it is the correct o-ring.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Has thanked: 292 times
Been thanked: 765 times
I just measured the O ring on a 98: it is 70 mm ID, and 5.5 mm thickness.
I think you've got the right part number, e.g. you can see it tucked away in the illustration here https://www.jimellisvolvoparts.com/show ... evel=20459 (if the link works).
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
WhatAmIDoing
erikv11 wrote: 24 Feb 2018, 16:42 I just measured the O ring on a 98: it is 70 mm ID, and 5.5 mm thickness.
Thanks, but what is the outside diameter?
Has thanked: 1850 times
Been thanked: 1710 times
Looking at tat part it fits under the electrical connector on the MAF from the drawing. It is not a large diameter 'O' ring that fits in the hole in the air-box where the MAF attaches.
I have even pulled the old hard copy parts listing and there is no 'O' ring listed that I can find.
If the ID is 70mm the OD is 70 + (2 x 5.5mm) = 81mm if my math is right!
I was looking at the diagram wrong, I think Neil is right.
See, https://www.jimellisvolvoparts.com/p/Vo ... 24462.html, correct part number is more likely Volvo 3524462.
I just measured it at 81 mm, Neil's math checks out. All measurements are with calipers. Here are some photos:
'06 S60 R, 197k
WhatAmIDoing
scot850 wrote: 24 Feb 2018, 17:28 Looking at tat part it fits under the electrical connector on the MAF from the drawing. It is not a large diameter 'O' ring that fits in the hole in the air-box where the MAF attaches.
Thanks. Nice to see I learned nothing about circles in all those years of maths. :roll: You confirmed my suspicions about what I thought the part really was.
erikv11 wrote: 24 Feb 2018, 19:23 I was looking at the diagram wrong, I think Neil is right.
You are a saint. That's the closest we've gotten to the right o-ring all day. How much searching did it take to find that diagram? Thanks for the pictures, now I actually have some idea of what this is suppose to look like.
Has thanked: 1505 times
Been thanked: 3818 times
No Oring in my spare. Thought it came with one,
T he MAF case is 80 mm outer diameter FWIW
WhatAmIDoing
abscate wrote: 25 Feb 2018, 14:52 No Oring in my spare. Thought it came with one,
Sounds like the 98 and 99 airbox is not the same. If a 98 o-ring is 70mm inside diameter, then that's 10mm of stretch just to get it on the MAF housing. Doesn't sound right. Guessing the MAF housing on 98 is a bit smaller diameter.
I just put the calipers on a 98 MAF and it is 70 mm OD, so yes the air box hole it fits into (with the o-ring installed) is probably 80 mm ID. I'm all done measuring though!
'06 S60 R, 197k
WhatAmIDoing
I do appreciate all the measurements. Now I know my plan to buy the o-ring for a 99 won't work. Going to hit up the local hardware and plumbing stores tomorrow and see if they have anything comparable to a stock o-ring. Unfortunately, all the local salvage yards only have 1999+ Volvos in their inventory.
