Should I consider buying 2004 C70 with manual 5 speed
tjg
Year and Model: 940 1995,XC70 1999
Has thanked: 3 times
Post by tjg »
Has 130,000 miles withhigh pressure turbo, in good shape. Any thoughts on what to look at in a $3,600 car? Jeff
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1993 940 TURBO(CRUSHED BY TREE)
1989 240(CRUSHED BY SAME TREE)
1972 142 SOLD
Has thanked: 1506 times
Been thanked: 3822 times
About $1500 in Cash??
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
That would be dealer's retail for clean condition. If it is a private party deal, knock off $1100. The people that think they can get dealer's retail on a private party transaction are delusional or looking for a sucker. The private party deal is, there is a trade in value that one can get from a dealer and the retail price.
The private party deal is the seller and buyer split the difference between trade in and retail ... more or less.
Why would one pay a private party full retail, when you can pay the same at a dealer and better hold the dealer accountable . Holding a private party accountable is a slippery slope. One would be a fool to take a risk and not get something for doing so.
I could bite at that price if the following had been done
New clutch
New AC evaporator
New MM throttle body
No play in front end or new LCA
tjg
Post by tjg »
Guess will go take look tomorrow. Is a MM throttle body like the Modex I put in the 1999 V70XC? I'm sure a clutch replacement is expensive and the LCA are not to bad to replace. Thanks for the replies.
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1972 142 SOLD
Has thanked: 293 times
Been thanked: 765 times
I don't like C70's so much :D but it's a decent price, probably $600 higher than usual for your market. I'm assuming it's in very good condition, to go along with the low miles.
As far as the actual question of your first post, what to look at:
- do the windows go up and down, this is a weak spot in C70s. Check all of the door hardware, locking mechanisms too.
- condition of the top and how well it seals/closes
- 130k is prime time for basically all suspension components to go (struts, spring seats, control arms)
- clutch as mentioned, but presumably it is original and just fine at only 130k
- PCV may have never been done, if so add that to the purchase cost it is time
- throttle body as mentioned
- the usual (evidence maintenance history, ask them what kind of gas they use is it high octane, what brand/weight of oil, what kind of driving, etc..)
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Of my two sticks , one is over 200k on the original clutch, the other needed a new one at 110k
Clutch dusk and pressure plate. $300
Dual mass flywheel. $750
9 hours labor $720
The throttle body is a $500 job
AC evap is a $100 part plus 10 hours body work
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Timing belt change?
Repair/maintenance records?
85 GLH, 367 whp
00 Insight, 72 mpg
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I like to ask why they're getting rid of it. If I see a shiny new car in the driveway it is obvious usually, other times it may be because a car has had one problem too many. If they disclose the problems, I'm more likely to buy it as then I know what I'm getting into.
When I am told there are no problems or they haven't had any problems I immediately get suspicious. You can't own a car and have no problems.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
wizechatmgr wrote: 10 Mar 2018, 18:21 I like to ask why they're getting rid of it. If I see a shiny new car in the driveway it is obvious usually, other times it may be because a car has had one problem too many. If they disclose the problems, I'm more likely to buy it as then I know what I'm getting into.
+1 June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
