The boot on the wire was torn as well. I changed the plugs in the rest of the cylinders and left this one alone.
What is the problem? Valve cover gasket...or worse?
So I haven't been able to get to that this weekend but I will open mine up this coming Saturday. I am curious as to what your plug looks like now?Looks typical of oil spillage either from a leaking cap or when pouring oil into the engine. It gathers in the plug holes. Suggest you dry out the area and put a new cap gasket on the filler cap. Good time to clean up the entire area and check for other problems. May need to change wires if they are old.
