Fuel pump unit
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
anbran123
Year and Model: S90 1998
Fuel pump unit
Post by anbran123 »
Is this crack going to be a problem (or is it just a housing for the tube)?
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I'd guess that corrosion is the cause of that crack.
1988 Volvo 760 Turbo Wagon
anbran123
Post by anbran123 »
I don't know. I was thinking that the guy who took it off was struggling with the hose fastener that goes on there and cracked it.
Is it normal for corrosion to cause a crack like that?
anbran123
Post by anbran123 »
Actually, here's a better picture. it does look like corrosion in there...
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
anbran123 wrote: 25 Mar 2018, 09:55crack like that?
I have no idea what I am looking at, but if that is a return line, you might get by with it.
There are bulkhead connectors for fuel lines, but again, I know nothing about this setup.
If a return line, maybe a new pipe with expoxy...or appropriate sealer.
anbran123
Post by anbran123 »
This is a picture of the main pressure line from the fuel pump. The top of the fuel pump/sending unit assembly...(In the trunk)
93Regina
Post by 93Regina »
I use to drive on 401 to Montreal...nice highway, at least in 1990s
If road salts are used in winter, this might explain what happened. If the tube feels firm with mild pressure, I would not be concerned.
I don't see how this connects, but it might be possible to replace this tubing. Keep in mind fuel pressure can rise above 40psi, and can hit around 100psi when return line is blocked...I've done this before on a test with a 245 Volvo.
Maybe lightly clean it off, and put a sealer around it.
