Ignition Coil Lifespan
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Here comes a "jynx post".
Before my first white engine plug change I called myvolvopartsonline.com (big Texas dealership parts dept.) to ask about coil availability because I anticipated dried wires cracking away due to heat.
The fellow on the phone said, "We stock 'em but I've never sold one". I haven't experienced a failure (3 V70's).
I do like abscate's "2 spares" approach to identifying a misfiring cylinder. I must get to a junkyard.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Georgeandkira wrote: 03 Apr 2018, 05:56 I do like abscate's "2 spares" approach to identifying a misfiring cylinder. I must get to a junkyard.
I have a couple spares, that I picked up at the Pick-n-Pull for $5 each, sitting on the garage shelf. The big question is whether they will still still work after being knocked off the shelf onto the floor numerous times :(
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
chrism wrote: 03 Apr 2018, 07:40
The Big Answer to the Big Question is:
Soak'em thoroughly in sea/ocean water for at least 15 days, this will remove all doubt.
(If access to the beach is restricted, then Aqua Regia is an option.)
:lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Has thanked: 1613 times
Been thanked: 4078 times
Georgeandkira wrote: 03 Apr 2018, 05:56 Here comes a "jynx post".
Stop in on your way through , I’ve got spares
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Every time I've had a misfire due to a coil the OBDII system has narrowed it down to the exact cylinder each time......I must be lucky. Have changed out about 5 of them on my own high mileage vehicles. I might add that on our XC90 2.5T I had an early failure at 170,000kms of cylinder 2 coil pack because of massive gaps on the worn out plugs.
I think if you have a coil failure and a constant miss you will get the right cylinder code, P030x
If you have rough running or an intermittent miss, the cylinder ID is not as robust.
One think I like about cheap plugs and 30k change interval...you don’t run into the large gap stress if you check them every 15k.
Been thanked: 504 times
Post by cn90 »
For those who insist on keeping the plastic cover in place, my recommendation is do not install all 6 Torx bolts.
Install only 4 Torx bolts at both ends.
The 2 Torx bolts under the Turbo pipe...leave them out
(save them in the trunk) bc these 2 Torx bolts are difficult
to remove with the Turbo pipe in place.
If you only have 4 bolts in place, then dealing with ignition
coil in the middle of nowhere is somewhat easier...
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
cn90 wrote: 09 Apr 2024, 11:26 For those who insist on keeping the plastic cover in place, my recommendation is do not install all 6 Torx bolts.
Good advice. Removing the turbo pipe is time consuming.
Post by cn90 »
Ok, so back to the debate: "replace as you go" vs "all 5 new coils"...
Used genuine coil is $15-$20 on eBay.
New Bosch coil (FCPEuro, eBay etc) is only $43/each.
So, to install all new, it is only about $215/for 5 Bosch coils.
What is everyone's doing?
Has thanked: 312 times
Been thanked: 818 times
As per discussions e.g.
viewtopic.php?t=100522
viewtopic.php?p=639095&hilit=mpg#p639095
I advocate to replace all 5 with new Bosch around the 180k - 200k, whenever convenient. If you already drive the car much, or plan to keep running it for a while, the replacement will in all likelihood quickly pay for itself.
High mileage coils will likely last a very long(er) time but I'm moving to only using them for troubleshooting or temporary repairs.
