Need help identifying part.
1996 - 2004 S40
1996 - 2004 V40
nooneau
Year and Model: V40 2002
Post by nooneau »
Part came apart, only spring left.
Would appreciate help. :)
Engine is hard to start, have to rev a little to get running.
Engine then runs between 600 and 1400 revs mostly in the higher range.
nooneau
Post by nooneau »
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
It might be listed on the vacuum hose routing sticker under the hood.
'84 Prelude
'06 MPV
'13 Ford Focus SE
Hendo22
Year and Model: 2004 s40 1.9l T
Post by Hendo22 »
Any problems you noticed with the car before you found this random spring??
Might be something from the thrttle cable? How does it idle? Do you have lag when pressing on the gas? Has the car died unexpectedly?
Hendo22
Post by Hendo22 »
Might be something from the throttle cable? How does it idle? Do you have lag when pressing on the gas? Has the car died unexpectedly?
PaddyM
Year and Model: 2003 V40 2.0T
Post by PaddyM »
I believe it's a a sensor or switch on the vacuum line that connects the brake servo to either/both the manifold inlet and the vacuum pump.
It's the dooby-whacker in this item on FCP.
https://www.fcpeuro.com/products/volvo- ... 0-30620958
I had an audible buzzing from the same part when I switched off the engine. On inspection I found the top and bottom piece starting to separate, which I fixed with electrical tape and a zip tie. That was 18 months ago now, and the brake servo still tests and works well.
Nice to see what the inside of it looks like though. Not sure if it some sort of a switch or sensor though.
