If you are using a gauge like this for the wastegate adjustment start on the low side of the pressure set point, set the rOd, then test drive. Typical error on a gauge will be 5% full scale or 1.5 psirguzz wrote: ↑06 Apr 2018, 06:51 Do Something like this, with the wastegate on the car. I use my brake bleeder and it's gauge to test mine. Mityvac should work. Diaphragm was broken, no vacuum, so replaced it with one from Ebay. There are numerous Youtube videos, Robert DIY links to adjusting properly, pretty easy even for me. 4.4 PSI on the rod, if I recall, though I did 6 PSI.
You don’t want to overboost or you will bend a rod.
I don’t think you are in a much danger with a 99 ME7 as that system monitors manifold pressure
