850 Timing Belt Replacement
banjoman
- Year and Model: 850, 1996
No doubt this is addressed on the site, but I could not locate it, so my apologies. My 1996 850 Wagon has 240k. The timing belt was replaced 7 years ago with 32,000 miles since. Should I replace it?
- Has thanked: 2652 times
- Been thanked: 1245 times
Yes. You're hitting the time limit, not the miles limit. It's 7 years/70k miles.
search.php?keywords=1996+850+timing+bel ... mit=Search
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Time is relevant...but with only 32k on the belt i would leave it for 2-3 more years...if that is my car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 292 times
- Been thanked: 765 times
If you do decide to replace it keep in mind that this would be an unusual timing belt service: you would only change the belt, because you were concerned the rubber is deteriorating.
A "normal" timing belt service would always replace the accompanying roller pulleys, and sometimes also the hydraulic tenisoner and water pump, etc.
Your climate (GA) is warm but doesn't see very extreme temp swings, so like misha says I might let it go another year or two if it was me. Definitely inspect the belt though, for cracks.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1504 times
- Been thanked: 3817 times
I would also run that 2-3 more years, but I am a risk taker.
I ran my 99 to 137k, 14 years
I’m running my New Beetle belt 15 years
