My parts guy can get two different Thermostat brands, Behr and Vernet.
Any recommendations?
Thermostat Brands
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Some say Behr didn't last at all, I'd be even less sure about less known Vernet...
http://www.m5board.com/vbulletin/e39-m5 ... m-not.html
Which car are we talking about (this being the forum for 2001 and up)
https://www.ipdusa.com/prodtype.asp?num ... at%20volvo
https://www.fcpeuro.com/Volvo-parts/Thermostat/
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Ooops I posted in the wrong forum, this is for my 850, I have the OEM (Wahler) one, but I find they fail after some time.
Mods can you move please.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
+1ashvolvo wrote: 07 Jun 2018, 10:17 Thermostats are cheap, do not use anything other than OE, and when you change the thermostat I would suggest changing the ECT as well.
- Been thanked: 504 times
I have used all of them. For your Volvo 850...
- Vernet is French, it is OK but the rubber gasket crumbled after 5y.
- Behr is OK.
- Wahler is OEM. It should last 80K-100K.
- Behr is OK.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I imagine Ashvolvo means a Volvo blue box part, Volvo coolant is in order as well. It's only $20 a gallon at the dealer parts counter.mecheng wrote: 07 Jun 2018, 10:29 Ooops I posted in the wrong forum, this is for my 850, I have the OEM (Wahler) one, but I find they fail after some time.
In my car I have the coolant replaced every other year since new. My factory thermostat was replaced with the timing belt and water pump that was 12 years and 109,000 miles. The thermostat was part of the service, that is the only reason it was replaced. It has been 2 years 51,000 miles since the replacement of the belt, pump, thermostat + housing. The thermostat is still fine. I had my dealership do that work so all parts were blue box genuine Volvo parts.
Honestly this is the first car I kept long enough to replace the thermostat. I have never had a Volvo overheat or have a thermostat go bad. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
I had CEL@ 140K for Thermostat. I changed the Thermostat and ECT sensor ( I think Volvo call it temperature sending unit) and flushed the coolant. This is the first change for the both the items.
1999 S-70 GLT @168K Miles
1987 740 GLE- Donated @215K Miles
- Has thanked: 2200 times
Our local dealer recommends changing the thermostat every 3 years. Part of that is the huge variation in temperatures I understand cause them to fail more often.
mecheng
Thanks, probably why the Behr is $19, and the Vernet is $10. I will try the Behr. The Wahler seems to last 120,000km or so.cn90 wrote: 07 Jun 2018, 11:46 I have used all of them. For your Volvo 850...
- Behr is OK.
