Thermostat Brands
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
My parts guy can get two different Thermostat brands, Behr and Vernet.
Any recommendations?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Some say Behr didn't last at all, I'd be even less sure about less known Vernet...
http://www.m5board.com/vbulletin/e39-m5 ... m-not.html
Which car are we talking about (this being the forum for 2001 and up)
https://www.ipdusa.com/prodtype.asp?num ... at%20volvo
https://www.fcpeuro.com/Volvo-parts/Thermostat/
ashvolvo
Year and Model: 1999- S 70 GLT
Post by ashvolvo »
Thermostats are cheap, do not use anything other than OE, and when you change the thermostat I would suggest changing the ECT as well.
1999 S-70 GLT @168K Miles
1987 740 GLE- Donated @215K Miles
mecheng
Post by mecheng »
Ooops I posted in the wrong forum, this is for my 850, I have the OEM (Wahler) one, but I find they fail after some time.
Mods can you move please.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
ashvolvo wrote: 07 Jun 2018, 10:17 Thermostats are cheap, do not use anything other than OE, and when you change the thermostat I would suggest changing the ECT as well.
+1
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I have used all of them. For your Volvo 850...
- Vernet is French, it is OK but the rubber gasket crumbled after 5y.
- Behr is OK.
- Wahler is OEM. It should last 80K-100K.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
mecheng wrote: 07 Jun 2018, 10:29 Ooops I posted in the wrong forum, this is for my 850, I have the OEM (Wahler) one, but I find they fail after some time.
I imagine Ashvolvo means a Volvo blue box part, Volvo coolant is in order as well. It's only $20 a gallon at the dealer parts counter.
In my car I have the coolant replaced every other year since new. My factory thermostat was replaced with the timing belt and water pump that was 12 years and 109,000 miles. The thermostat was part of the service, that is the only reason it was replaced. It has been 2 years 51,000 miles since the replacement of the belt, pump, thermostat + housing. The thermostat is still fine. I had my dealership do that work so all parts were blue box genuine Volvo parts.
Honestly this is the first car I kept long enough to replace the thermostat. I have never had a Volvo overheat or have a thermostat go bad. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
ashvolvo
Post by ashvolvo »
I had CEL@ 140K for Thermostat. I changed the Thermostat and ECT sensor ( I think Volvo call it temperature sending unit) and flushed the coolant. This is the first change for the both the items.
Has thanked: 2199 times
Been thanked: 1852 times
Our local dealer recommends changing the thermostat every 3 years. Part of that is the huge variation in temperatures I understand cause them to fail more often.
mecheng
Post by mecheng »
cn90 wrote: 07 Jun 2018, 11:46 I have used all of them. For your Volvo 850...
- Behr is OK.
Thanks, probably why the Behr is $19, and the Vernet is $10. I will try the Behr. The Wahler seems to last 120,000km or so.
