Passenger Power Seat not working Topic is solved
pb49415
Year and Model: 1998 S70
Post by pb49415 »
abscate wrote: 07 May 2018, 10:45 The reset inside, once they cool off from overcorrect. It sounds like supply side is good, so you have to fault trace backwards from the known lack of 12V back to the circuit breakers.
Wiriing diagrams for these cars are free online, but we don't host here by legal agreement with Volvo
Iโ€™m in no hurry, but can you suggest a website I could look at? Sounds like a lot of disassembly on the interior. Not a clue where to start following wire bundles. I figure under the center console then up behind the dash. I already took the dash off over the weekend to reinstall a chrome ring that had fallen off the tach in the gauge cluster. Took about a half hour total job. But, a website for now would be great, but I understand legal stuff.
Thanks a lot for your assistance!!!! Itโ€™s been a big help.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I think the site is volvowiringdiagrams.com but the scans are poorly paginated and they are incomplete. The seats should be the same 98-00 so grab all three years - sedan and wagon.
I have better luck using the service manual but it so for the 850: www.matthewsvolvosite.com/downloads/Volvo_850.zip
I have not compared the two but circuit wise they are likely identical or very close to it but I don't know if the wire colors changed.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
BEJinFbk wrote: 07 May 2018, 01:54 If weโ€™re talking about the same things,
those metal cans arenโ€™t fuses, theyโ€™re
thermally tripped auto-resetting circuit
breakers. Have you tried swapping them?
I Had one those circuit breakers fail on me, you have to remove the 4 torx screws at the cowl located fuse box to get to them.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Reach up from the back side near the seat hinge and feel for a cam flopping around. The cam control a micro switch that tells the control module when the seat back is tilted or not. The cam is spring loaded and one attachment is plastic. When the plastic attachment breaks the the micro switch is in tilted mode all the time and seat controls are disabled.
This is a common on the P80 seats. Once you figure out how it works, the fix is easy. I substitute Elastic Hair Bands for the spring to correct the problem. Feed the Elastic Hair Band through the hole on the cam, on the front side of the seat post there is a square hook to hold the other end of the Elastic Hair Band. Five minute fix after you know where to attach the Elastic Hair Band.
Active
Past
pb49415
Post by pb49415 »
I just looked and felt around for the switch/Cam around the hinge area. I did not see or feel anything. I donโ€™t think my s70 has one. Am I just missing it?
RickHaleParker
Active
Past
pb49415
Post by pb49415 »
Well the mystery has been solved. I was just talking with my buddy that gave me the car. He told me the car didnโ€™t originally come with a power passenger seat. He added it after the fact. Jumped power off the heated seat button. You have to have the heater button on for the seat to work. Wow. I would have never guessed. Never use the seat heaters.......at least I learned a lot more about the car and the wiring/controls. ๐Ÿ˜€. Knowledge is always a good thing!!!!
Has thanked: 1611 times
Been thanked: 4075 times
Well done. The internet does not carry all the answers
pb49415
Post by pb49415 »
Thanks ๐Ÿ‘๐Ÿผ
