Coolant Pipe Bolt Hole Stripped! 850 Topic is solved
Dmck
Year and Model: 1995 850
Has thanked: 2 times
Been thanked: 3 times
Post by Dmck »
Man am I screwed, or should I say I wish I could screw!
So after a full head gasket job on volvo 850, the last bolt I put in, I managed to strip the lower bolt hole of the coolant pipe on the back of the head next to the exhaust. It just spins and spins! I think I cross threaded it and mashed the threads.
Is there any possible bolt replacement that has slightly larger thread than the M7 x 1 that goes into the coolant pipe hole?
has anyone done this and found a fix that doesn't require complete tear down and a helicoil or similar? What a mess!
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
I wouldn't worry about it too much. Get some high temperature tape and wrap the bolt and put some lock tight in the hole. Or find the American equivalent next size up,...
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
As you can kill your engine with a coolant leak I would fix it right. How much space do you have to get a tap in there?
As MDK suggests using an American equivalent may be an option. You need to see what the biggest bolt you can get into coolant pipe is or better yet enlarge the coolant pipe hole before installing it - then pick your bolt size. Make sure what ever size you pick - the bolt head can be seated all the way down without interfering with the pipe. You may have to switch to an allen or torx head here.
Visualize and dry fit the scenario before electing any approach. Right now is the time to think everything through.
Measure the depth of the current hole and the length of the current bolt. If the replacement bolt is too long it will strip out the head threads(this could have been your original issue).
Just measure the depth and take your time. The tap should go in straight without much issue. Due to limited space it may take a little longer. Clean out the hole with some carb cleaner or equivalent.
Dmck
Post by Dmck »
I went and got a few different bolts
Some m7, m8, and 5/16th (7.9mm)
If you were to clean strip a 7mm hole does that mean it is ready to tap to 8mm?
I will see how deep hole is and do some testing and go buy the tap.
has anyone ever just bolted in an 8mm into a stripped 7mm hole with now tap?
It looks like Home Depot here has a lot more options for 5/16 taps..
Is there any reason to not make it a 5/16 hole over an 8mm
Dmck
Post by Dmck »
SuperHerman wrote: 05 Jul 2018, 17:44 As you can kill your engine with a coolant leak I would fix it right. How much space do you have to get a tap in there?
There is a pathetic amount of space to work with but if I can put a bolt in I can tap it I would think. Hopefully the coolant pipe itself can support and 8mm or 5/16th bolt
SuperHerman
I don't know the answer to your question about "clean strip", but if one looks up the specs of the bolts they will find the answer. I have never looked at the question from your question perspective, but I have looked up specs and seen cross sections and measurements for the various bolts. The piece of information I would imagine is relevant is the thread depth and dimensions.
I have mangled larger bolts into ATVs in the past, only to regret the move and have to retap and helicoil later.
I am not sure you understand my coolant pipe clearance - it may be a non-issue. On my turbo return line I was thinking of swapping the torx head to a 10mm head, but it will not work as the head will hit the pipe line (too wide). Not sure on your coolant pipe you may have plenty of space between flange holes and the pipe. What ever bolt size you elect to use - dry fit and enlarge as necessary the coolant pipe hole and the gasket hole.
Dmck
Post by Dmck »
SuperHerman wrote: 05 Jul 2018, 18:25 I don't know the answer to your question about "clean strip", but if one looks up the specs of the bolts they will find the answer. I have never looked at the question from your question perspective, but I have looked up specs and seen cross sections and measurements for the various bolts. The piece of information I would imagine is relevant is the thread depth and dimensions.
It looks like I am majorly screwed. The coolant pipe hole that you go through to bolt it down is too small to take an 8mm or a 5/16th. To fix this problem I am either going to have to remove the coolant pipe and drill the hole bigger in it, then tap the hole in the head, or remove the head, OR drill through both and hope I line it up right (not worth it)... my only true/safe option it to start completely over and do a full head gasket job.
I'm going to try the idea with tape above before I throw in the towel for a few days and do the whole job over. This is my car so I'm not on a deadline.
luckily I have my t-5r as my backup, but I don't like that being my dependent daily driver car.
Once I get back to having the head off I'll start recording the process in this thread so if any sorry sob does what I do they will see what is needed.
Doh!
And what I will need to drill bigger once back down to the block.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
I ran into a similar problem on my 855 turbo. I think at factory assembly those bolts are dipped in a heavy sealant / locker type stuff. After you remove the bolt, a lot of that stuff remains in the bolt hole, so when you reinstall the bolt you run into it. The hole is effectively too short to bottom out the bolt head firmly enough on the flange to get a good water seal.
I got the tap for the factory bolt but had to borrow a driver chuck from the local shop to run the tap in to clean out the threads. The tap wasn't square cut at the end, it was tapered, so I still couldn't clean out the hole to its original depth. Rather than risk what you did, after cleaning the threads as well as I could, I "shortened" the bolt with a couple of flat washers and gently torqued it tight enough so it doesn't leak.
I feel your pain.
BTW: if you drop the pan to do your oil pickup o-rings (while you're in there) watch out for that same problem on the pan bolts. Clean out those holes with your tap as well, especially the long bolts by the rear main.
Dmck
Post by Dmck »
JimBee wrote: 05 Jul 2018, 21:08 I ran into a similar problem on my 855 turbo. I think at factory assembly those bolts are dipped in a heavy sealant / locker type stuff. After you remove the bolt, a lot of that stuff remains in the bolt hole, so when you reinstall the bolt you run into it. The hole is effectively too short to bottom out the bolt head firmly enough on the flange to get a good water seal.
I feel your pain.
Thanks for the oil pan tip.
I realize if I pull the head I don't have to drill the coolant pipe hole and just have to helicoil the hole in the head back to fit the original m7 x 1. So at least there is that!
I have also never worked with helicoil so ill get some practice in.
SuperHerman
You should be able to buy a tap set for about $10 - or the specific tap for a few bucks. Don't give up on a proper repair so easily. You could blow a leak in a year and be out in the middle of no where. Just not worth it.
You just need to pull up the specs for the existing bolt and the proposed bolt. Take a look at this as a starting point:
https://en.wikipedia.org/wiki/List_of_d ... _tap_sizes
or this one -(Which sounds exactly like yours)
https://mechanics.stackexchange.com/que ... t-drilling
Drilling through the coolant pipe is pretty easy - just remove the gasket, tape up the hole and drill. If you have to borrow an angle drill or angle drill adapter (you can get these at Mendards) and you should be able to do it in car. A flexible shaft adapter would also be an option for drilling out the coolant pipe.
