Transmission was replaced with a manual. When I purchased the car it already had a manual swap done and it worked fine, shortly after I took it to a shop to replace the clutch. The car never had any problems after that except for a bad syncro. I replaced the manual with another one. The serial number on the new one is 197700. Also I have a pictures of the key and wiring diagram. Im not really sure what I would be looking at though. When I was checking for power I checked a26.misha wrote: ↑15 Jul 2018, 09:06 You missed something.
The fact that you don't have check engine light along with all other lights when key is in pos.II,means that ecu is not getting any power.
With symptoms you have i doubt that the bulb is burnt out in the process.
You mentioned that transmission is replaced...was it auto or manual like now?
Link for wiring diagram
