Hey Everyone,
I’m new to the forum. I just recently purchased a 1994 Volvo 850 non turbo. It has 128,000 miles on it.
I don’t know too much about it’s mechanical history besides that the timing belt was done at 98k and the previous owner replaced the coolant temp sensor and thermostat.
I’ve had the car for about two months. I replaced the battery. It was shot. The car ran great up until a week ago. The car will randomly just shut off and then crank no start. If I wait an hour or so it will start back up again as if nothing happened. The idle seems to be ok.
I noticed the car still has the original 94 bougicord spark plug wires. I have no idea if anyone has ever done any maintenance on the vehicle.
Anyway, how should I proceed?
94 850 n/a intermittent stall, crank no start
- RickHaleParker
- Been thanked: 977 times
It does sound like you may have a intermittence in the electrical system.
Do a thorough inspection of the electrical wiring. Damaged wires that maybe shorting out. Dirty, corroded or loose connectors that maybe opening.
Active
Past
Past
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
My 94 did same thing, also with no codes, until the camshaft position sensor was replaced. It is a silver cylindrical disk just aft of the cap and rotor. Check for corrosion on the connector first. It may not be the issue but is simple to look at.
- Been thanked: 4064 times
You will have to wait for the nonstart and then make a snap diagnsosis to get the right branch on then diagnostic tree.
I suggest starting fluid to check for fuel delivery problems. A pro would put a fuel pressure gauge on the rail and confirm correct pressure
If you want to throw parts, fuel pump relay and ignition switch electrical part would be the top candidates
Things it isn’t....bad gas, plugged fuel filter, bad oxygen sensor, bad catalytic converter, or bad ECU
- 2638 Views
Last post by malty
- 29 Replies
- 7140 Views
Last post by Chuck W
- 1265 Views
Last post by Salomons Driveway
- 3451 Views
Last post by Empathron
- 2119 Views
Last post by BrickBetty
