squeeky steering wheel
davern444
- Year and Model: 98 S70
The steering wheel in my 98 S70 has a creeky groan inside the car when I turn it sometimes and it sounds like it's coming from right under the wheel near the dash. I recall reading something about it being a bad bushing or something but can't seem to find that post despite searching several times. Anyone have this issue and what bushing are they talking about? It's really annoying and I want to fix it. Any insight or direction is appreciated.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Yep, I had that for years. There's a bushing with bearings at the bottom of the steering wheel column inside the car, covered in a plastic plate. The only way to permanently fix it is having the boot and bearing replaced. I had a mechanic do it while replacing my subframe bushings.
Some people have luck shooting some lubricant/grease into the boot, but it's often only a temporary solution as it was for me.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
davern444
Thanks, I'll check it outecbsykes wrote: 10 Aug 2018, 05:32 Yep, I had that for years. There's a bushing with bearings at the bottom of the steering wheel column inside the car, covered in a plastic plate. The only way to permanently fix it is having the boot and bearing replaced. I had a mechanic do it while replacing my subframe bushings.
- Has thanked: 2199 times
Try silicon oil sprayed between the plastic boot and the shaft at the bottom as suggested.
- 947 Views
Last post by kaneelschep
- 1214 Views
Last post by WillieEvans
- 11 Replies
- 1400 Views
Last post by Blacklab467
- 6083 Views
Last post by EngineeringBloke
- 2061 Views
Last post by FLXC90
