(OEM) Single Use hose clamp
Has thanked: 1613 times
Been thanked: 4077 times
Mr. Detail wrote: 18 Aug 2018, 13:47 Thanks everyone for your responses. Now I have to see if I even have access under the car for that charcoal canister hose.
Drop the canister a bit for access then use line pliers to tighten the clamp.
It’s not critical on Evap parts under vacuum. You are just stopping the hose from falling off
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
$5.00 per clamp .. I use Zip ties in lieu of Oetiker clamps. So far no issues. I use a Cable Tie Gun to tighten the Zip tie until it snaps then dike off the excess.
Active
Past
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 158 times
Been thanked: 6 times
Post by Mr. Detail »
Are cable tie guns cheap?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Zip ties are available in various grades, some are actually a bit pricey. Over time the cheaper ones don’t fair all that well when used in a high temperature environment and/or a dry climate. They can get pretty brittle.
RickHaleParker
You can pick up a good one on eBay for ~$15.00.
You can get all plastic ones for less but, the all plastics one do not have any mechanical advantage. The lack of mechanical advantage can be hard on older people with diminished hand strength.
Active
Past
RickHaleParker
The Nylon ties I use have a temperature range of -40°F to 185°F (-40°C to 85°C). I figure as long as it does not get heated by the exhaust or come in direct contact with the block, It will be OK.
Active
Past
Mr. Detail
Thanks much RHP for your response.
Durenol
Year and Model: Volvo 2007
Has thanked: 2 times
Been thanked: 4 times
Post by Durenol »
As someone passing by this thread, what's the advantage of using these clamps vs the normal screw-tightening kind? These appear to be more expensive with no obvious benefit.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Durenol wrote: 21 Aug 2018, 13:15 As someone passing by this thread, what's the advantage of using these clamps vs the normal screw-tightening kind? These appear to be more expensive with no obvious benefit.
They're much faster to use on an assembly line.
Durenol
Post by Durenol »
That makes sense. I guess I should have clarified though that I mainly meant "for a joe sixpack working under his car", as I don't understand why you'd pick these over normal clamps that are cheaper, reusable, and don't require a special pair of pliers. Is it just for people who are obsessive about stock parts?
