This was a whole lot of unpleasant work but im so glad it happend now that im on the other side. My old motor was worn out more than i realized. My new motor is working grear and much faster and my car is running better than ever.
Just goes to show sometimes amazing things arrive wrapped up in a whole lot of unpleasant.
Built 98 S70 t5 - no oil pressure recovery questions Topic is solved
Socalboostin
- Year and Model: 98 s70 t5m
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
I´m amazed at how fast you pulled that off!
Btw, how exactly did that floor jack trouble start? Where did you put the jack?
Asking out of curiosity and also because I´ll have a second try on my hydraulic motor mounts and need to lift the engine a bit for that purpose.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
Socalboostin
Unfortunately it wasnt my first time pulling a t5 motor. Had the old out 4 months or so back for the manual swap and an overhaul and long story short... it leaked from new rear main seal after i reinstalled the motor and i had to pull it a 2nd time. So went much faster this time even wirh pulling donor motor. Could probably do it with eyes closed at this point.
You can either use a lift/hoist to lift the motor or put a 2x6 beteern oil pan and jack. Ive done both ways successfully in the past but going forward i wont be putting anything against my oil pan just seems too risky.
I was attempting to get the car real high off ground so had placed my floor jack with a chunk of 2x4 on top under the subframe (same as i had done many times before), except this time it just didnt line up right and before i could do anything slid off the 2x4 and edge of jack got the oil pan barely punching two tiny slits in it.
- Has thanked: 1497 times
- Been thanked: 3810 times
Did you do the engine and trans drop vs a cherry picker? Interested in your take on that.
Socalboostin
Never dropped the tranny via subfrane even though ive read its quicker. For me since ive pulled these motors before once or twice i dont think it would be quicker plus less rime under the car is better in opinion. Not much to pulling it right out the topside really.
