2006 v70r iginition wires
eggsaladhat
- Year and Model: 2006 v70r
I can't find a part number or listing for the wire that go to the ignition coils. Does anyone know what it is and where i can find it?
- Has thanked: 1507 times
- Been thanked: 3822 times
It’s part of a the main wiring harness, a big one. Probably way too expensive to consider over a repair job.
Edited.
Edited.
- Been thanked: 472 times
- Best is to do a "butt connector" repair job.
- Do NOT solder new wires, use butt connector.
- Also, if you want to be particular about it, then use shrinkable tubing to seal the butt connectors.
- RickHaleParker
- Been thanked: 958 times
Solder the wires. Butt connectors where never intended for permanent repairs and they fail often.
The Soldering in the picture are cold solder joints, the solder did not flow. The copper is not clean and was not heated enough to melt the solder.
The solder iron is used to heat the copper not melt the solder. That is the copper should be heated enough that one can take away the iron and melt the solder directly on the copper.
The solder will melt and flow across the surface of the copper and become part of the joint if the copper is clean and heated enough. Solder should be part of the joint not "glue" tacking it together.
Do a nice heat NASA solder repair , don’t forget to install the heat shrink first, well away from the solder area
- RickHaleParker
How to splice wires to NASA standards.
[youtube][/youtube]
Observe: She never touches the solder to the Iron ...
[youtube][/youtube]
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I would suggest hitting the junkyards... only I have no idea where does that wire loom end in order to be able to remove it from the donor car
I also notice one of the wires has too small gauge, in particular here there's quite some current running so it needs repaired properly (and insulate really well with electric tape)
- RickHaleParker
The engine and transmission is all one big harness, it terminates at the ECM & TCM. A new one would knock him back ~$900.00.
eggsaladhat
Thanks all. I'm going to nasa solder it for now and probably put a larger gauge wire in.
- 18 Replies
- 2783 Views
Last post by joe_pinehill
- 808 Views
Last post by coflynn
