IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2006 v70r iginition wires
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
eggsaladhat
Year and Model: 2006 v70r
Has thanked: 0
Been thanked: 0
United States of America
eggsaladhat
Post by eggsaladhat » Sun Sep 02, 2018 10:05 am
I can't find a part number or listing for the wire that go to the ignition coils. Does anyone know what it is and where i can find it?
you can see why i need to replace it
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 316 times
Been thanked: 979 times
Trinidad & Tobago
Re: 2006 v70r iginition wires
Post by abscate » Sun Sep 02, 2018 2:05 pm
It’s part of a the main wiring harness, a big one. Probably way too expensive to consider over a repair job.
Edited.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Year and Model: 2004 V70 2.5T
Has thanked: 0
Been thanked: 131 times
Post by cn90 » Sun Sep 02, 2018 2:13 pm
- Best is to do a "butt connector" repair job.
- Do NOT solder new wires, use butt connector.
- Also, if you want to be particular about it, then use shrinkable tubing to seal the butt connectors.
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 22 times
chrism
Post by chrism » Sun Sep 02, 2018 9:46 pm
Cn90, I’m curious as to your preference for butt connectors over solder. Is the environment too hot for solder?
RickHaleParker
Has thanked: 3 times
Been thanked: 539 times
RickHaleParker
Post by RickHaleParker » Mon Sep 03, 2018 12:43 am
Solder the wires. Butt connectors where never intended for permanent repairs and they fail often.
The Soldering in the picture are cold solder joints, the solder did not flow. The copper is not clean and was not heated enough to melt the solder.
The solder iron is used to heat the copper not melt the solder. That is the copper should be heated enough that one can take away the iron and melt the solder directly on the copper.
The solder will melt and flow across the surface of the copper and become part of the joint if the copper is clean and heated enough. Solder should be part of the joint not "glue" tacking it together.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
Trinidad & Tobago
Post by abscate » Mon Sep 03, 2018 4:31 am
Do a nice heat NASA solder repair , don’t forget to install the heat shrink first, well away from the solder area
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Sep 03, 2018 4:38 am
How to splice wires to NASA standards.
[youtube][/youtube]
Observe: She never touches the solder to the Iron ...
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 266 times
Canada
oragex
Post by oragex » Mon Sep 03, 2018 6:01 am
It’s part of a main wiring harness, a big one. Probably way too expensive to consider over a repair job.
I would suggest hitting the junkyards... only I have no idea where does that wire loom end in order to be able to remove it from the donor car
I also notice one of the wires has too small gauge, in particular here there's quite some current running so it needs repaired properly (and insulate really well with electric tape)
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Sep 03, 2018 7:45 am
The engine and transmission is all one big harness, it terminates at the ECM & TCM. A new one would knock him back ~$900.00.
These users thanked the author RickHaleParker for the post:
oragex
eggsaladhat
Has thanked: 0
Been thanked: 0
eggsaladhat
Post by eggsaladhat » Mon Sep 03, 2018 7:58 am
Thanks all. I'm going to nasa solder it for now and probably put a larger gauge wire in.
